1240AG Access Point/Native VLAN/VLAN Problem
smartin
Level 5
Level 5
Need to setup several SSID's with different Encryption levels. The access point connects to a plain D-link switch, not able to define a truck on the switch which is causing problems when only one of the SSID's is set for Native VLAN (DHCP server cannot be contacted with the other SSID's).
Anyway to get around this problem !!!!
Scott Fella
Nope.... you need to be able to define the vlans on the switch. You need a switch where you can configure a dot1q trunck and then you can make this work. Right now, you can only have one.
-Scott
