1242AG Help
KeithN123
Level 3
Level 3
I am trying to configure a
1242AG with 2 Vlans, Guest and Admin - there is an example paper by Cisco showing just this scenario but it doesn appear to work-  I was convinced the configuration is correct but the users PC cannot see either SSIDs - Guest is set to WEP and Admin is set to WPA2 TKIP - is there any way I can show that the 1242 is transmitting ?
many thanks
remove from the global config
dot11 mbssid
And under interface interface Dot11Radio0
Add
mbssid
and change to
station-role root
And test again
5 Replies 5
andrew.prince
Level 11
Level 11
Post your config - or the url to the article.
config as requested
dot11 mbssid
Add
mbssid
and change to
station-role root
And test again
Andrew -
apologies for the rating - I tried to give it maximum
but for some reason only got 4 star !!
Many thanks for your help
regards
Keith
Keith - no problem, thanks for the rating anyway - appreciated.
