1262N Bridge Questions
jcleary
I have 2 Buildings located about 1000 Feet apart, I am replacing a failed Bridge and antennas that were working for several years,
I Have 2 1262 N AP's using AIR-ANT2460NP antennas on each, I have this working and I think i have this set up correctly in my lab.
But i have a couple of questions.
What speeds should i expect to see? I'm hoping for N Speeds
Is there a way to see which rate was negotiated?
Do i need to set the Antenna Gain to 6DB in the radio configurations?
Do these leads from the antennas need to be connected to a specific connector on the AP in the 2.4Ghz side?
and one more.
I have this set up as Root Bridge and non root bridge. Is there any reason i should do it this way over WGB? There are no clients connecting, Just a bridge here..
Thank you so much.
Joe
Scott Fella
Depending on how the AP decide on its modulation, that will tell you what connection you will get.
This command will show you your connection info
show dot11 association [Client mac address - xxxx.xxxx.xxxx]
-Scott
Scott Fella
Forgot:)
As far as the antenna connection goes, I would just make sure the middle lead is on the middle port. WGB is not needed, just to root to non root.
-Scott
Thanks for the reply..
These are the rates it is showing
1.0 , 2.0 , 5.5 , 11.0 , 6.0 , 9.0 , 12.0 , 18.0 , 24.0 , 36.0 , 48.0 , 54.0 ,  m0-2 , m1-2 , m2-2 , m3-2 , m4-2 , m5-2 , m6-2 , m7-2 , m8-2 , m9-2 , m10-2 ,  m11-2 , m12-2 , m13-2 , m14-2 , m15-2 Mb/sec
Any idea what the m0-1- though M15-2 mean?
