Hello All,
I was wondering if there was a setting or a command that will allow me to set the guest wireless password to expire? Right now I have it set to broadcast guest wireless but would like to know if there was an option to make it expire after 30 days or so.
here is what I currently have configured
dot11 ssid 881W_Guest
vlan 41
max-associations 1
authentication open
authentication key-management wpa
mbssid guest-mode
wpa-psk ascii 7 001242365416542312402125
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 1 mode ciphers aes-ccm tkip wep128
encryption vlan 41 mode ciphers tkip
broadcast-key vlan 1 change 30
ssid 881W_Guest
ssid 881W_LAN
antenna gain 0
mbssid
station-role root
Solved! Go to Solution.
only if you somehow tied it to your AD/LDAP, and used those policies
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Not for a PSK there isn't. You would need to manually change it in 30 days, or have a script do it.
HTH,
Steve
So there is no functionallity on this device even if I use diffrent authentication Protocol?
HTH,
Steve
