1310 AP in Bridge mode.
Stewart Thomas
I have a 1300 AP that is in Bridge mode. I can always ping the access point, no network connectivity issue to AP. The issue that I'm having is the Printer connected to the AP. When I ping the printer from my laptop it will time out. If I log into the AP send a ping to the printer it will work. Once the ping sent  from the AP it will start pinging from laptop as well. I have tried another printer it does the same thing. I have also manualy set the duplex to full. That did not help either. So basically I can't ping the printer unitl I start up a ping from the AP that it is connected to first. Just wondering if anyone else has ever ran into this.
6 Replies 6
Scott Fella
You might be loosing the arp entry... the printer might not be responding back so the arp will timeout.  You can try to create a static arp entry on your layer 3.
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
Added the static arp. We will see what happens.
Did you see the arp timeout by chance?  Keep us posted also.
Scott
-Scott
No dice still same issue.
Don't know what else you can do.
Scott
-Scott
10/4
