1310 Bridge association problem
donoldridge
Community Member
I have successfully setup a pair of 1310s in the past as a wireless bridge. I have another pair I want to repeat this with, but I cannot get this set to associate.
I have tried other suggestions, and followed the setup directions in this link: http://www.cisco.com/en/US/products/ps5861/products_configuration_guide_chapter09186a00804ed72c.html#wp1056092
which I noticed in another post.
Included are my test configs, they don't associate.
Any help would be much appreciated. I am running 12.3(7)JA4 on both, but have tried other versions as well.
Thanks.
john.preves
Level 7
Level 7
It looks like you have bits of aaa authentication, and about two others. Pick which authentication you want and use that.
This looks like you cut and pasted a few things together.
Unfortunately I do not know enough to tell you what you did wrong specifically, but if you use the link you provided you will see that your configs do not resemble the configurations in the link.
Hello There,
Looks like the non root ssid needs to include 'authentication open'under the Cisco ssid on the root side.
Aaron
