1310 - problems with multipoint network.
talamo
Community Member
I have of the problems with one developed network wifi on three points. I have developed the network with a point of access used in modality "repeater", a mobile point in modality "workgroup-bridge", a fixed point in modality "root AP-ONLY". The mobile point is a ship that enters in the port in determines moments to you of the day. All it seems to work BUT when the ship enters in the port, the repeater becomes unstable. The link associations pass in state down, the interface radio of repeater goes in modality reset. In the log is evidenced only the fall of link. What could cause this instability? I accept whichever council.
Antonino
mchin345
Level 11
Level 11
Attacks that use ICMP "hard" error messages Attacks that use ICMP "fragmentation needed and Don't Fragment (DF) bit set" messages, also known as Path Maximum Transmission Unit Discovery (PMTUD) attacks
Attacks that use ICMP "source quench" messages
Successful attacks may cause connection resets or reduction of throughput in existing connections, depending on the attack type
