1310 wireless outdoor bridge - strong Encryption configuration - high priority
lerner cisco
Hi All,
Below  is bridge configration .  I would like to know with this below   configuration data traffic will get compelete encrytion ?? any better  encryption configuration  ?? as I read wpa will not provide complete  encryption. please help
network topology
R1--------------SW1<----------------->  root bride-1 <---------------------------> Non-root bridge-1  <------------------------ >SW2( remote office)--------LAN  hosts
SW1- Gi0/0- 10.200.32.1/29             BVI- 32.2/29                               BVI -  32.3/29                                   SW2-GI0/0 - 32.4/29
network setup :  SW1 - LAN port to root bridge connection --  Gi 0/0 - ip address configured -10.200.32.1/29
                         Root-brdge -------------------------------------------- BVI  10.200.32.2/29 -----
                         Non root bridge----------------------------------------BVI 10.200.32.3/29
                         SW2 LAN port-Non root bridge ----------------- Gi0/0  10.200.32.4/29
both bridge have only BVI configured and no VLAN or subniterface on the both bridge .
SW1 and SW2 port connected to bridges are not part of vlan  , ports configured with specfic IP address
dot11 ssid
   authentication open
   authentication key-management wpa
   wpa-psk ascii 7 123456
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm
station-role root bridge
bridge-group 1
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
bridge-group 1
hold-queue 80 in
interface BVI1
ip address 10.200.32.2 255.255.255.248
no ip route-cache
ip default-gateway 10.200.32.1
ip http server
no ip http secure-server
control-plane
bridge 1 route ip
************************************Configuration  on non root  bridge.******************************************************************
dot11 ssid
   authentication open
bridge irb
no ip address
no ip route-cache
bridge-group 1
no ip address
no ip route-cache
bridge-group 1
hold-queue 80 in
interface BVI1
ip address 10.200.32.3 255.255.255.248
no ip route-cache
ip default-gateway 10.200.32.2
ip http server
control-plane
bridge 1 route ip
Hi there ..
I want to make sure I understand. You are concerned about the encryption of the wireless tranmission over the bridge correct ? I see based on your config you are using WPA/AES. This isnt standard based, if you wanted to be more stnadards based you should use WPA/TKIP or WPA/AES. Both are very secure. I would lease with WPA/AES. Again this is only for the encryption.
If you want stronger authentcation you might consider 802.1X.
__________________________________________________________________________________________
lerner cisco
can any one help me on this please
Hi there ..
