1510 and 1520 compatibility
mohammadazizi
We have mesh network with WLC 4402 (4.2.207.0) and LAP1510AG-A-K9
Now we want to add more Cisco AP's to our network as a RAP or MAP
I want to know 1522 AP can compatible to 1510 with below details?
Cisco Aironet 1510 MAP
Cisco Aironet 1522 MAP
Cisco Aironet 1510 RAP
Yes
Yes
Yes
Yes
Cisco Aironet 1522 RAP
Yes
Yes
Yes
Yes
Yes and Yes.
HTH,
Tiago
If  this helps you and/or answers your question please mark the question as  "answered" and/or rate it, so other users can easily find it.
5 Replies 5
Surendra BG
Release 4.2.207.54M does not support Cisco 1520  (1522, 1524) series mesh access points. Cisco 1520 series mesh access  points are supported in release 5.2 (and later) of the controller  mainline release.(PLEASE Check the Release notes and then proceed further..)
here is the release notes..
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn4220754M.html
Complete Release notes..
http://www.cisco.com/en/US/products/ps6366/prod_release_notes_list.html
Lemme know how this answered your question.. Please rate the post if this was usefull..
Surendra
Surendra BG
Thanks for your reply, but I want to know wich released could support 1510 and 1520 together as a RAP and MAP
We have WLC 4402 and 1510 AP, now we want to add more LAP, as you know 1510 is discontinued, please advice me how we can add LAP to current mesh network?
Please take a look at this document:
http://www.cisco.com/en/US/prod/collateral/wireless/ps5679/ps6548/bulletin_c78-542046.html.
There you can see what are the APs supported in each release.
You will notice that:
4.1.190.5 supports 1505, 1510, 1522 (-US,CAN).
4.1.191.24M supports 1505, 1510, 1522 (-ROW).
4.1.192.35M supports 1505, 1510, 1522, 1524 (-PS).
So, I would go for 4.1.190.35M if you want to have full compatibility between 1510 and 1522:
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn4119235M.html.
HTH,
Tiago
Thank you for helpful reply, full compatible means Interoperability of 1510 RAP compatible with 1522 MAP and 1522 MAP compatible with 1510 MAP as below table?
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
and the last question: all of this workable on one controller with software release 4.1.192.35M?
Yes and Yes.
HTH,
Tiago
