1530 Mesh network no WLAN
I have cisco controller on virtual machine, and two 1530 AP: one (Root AP) connected via ethernet, second (Mesh AP) connected via wireless, they both successfuly register to controller, yet there is no SSID to connet. What have I missed?
Scott Fella
The vWLC only supports FlexConnect mode Access Point. Per the doc:
Outdoor Mesh Access Points (an Outdoor AP with FlexConnect mode will work)
Note: Outdoor APs such as AP1552 are supported in FlexConnect mode if the APs are not used in a mesh deployment.
http://www.cisco.com/c/en/us/support/docs/wireless/virtual-wireless-controller/113677-virtual-wlan-dg-00.html#support
-Scott
Scott Fella
-Scott
Now I understand why there was no WLAN in local mode too.
With the vWLC, you will not be able to use MESH. The 1532's can be configured for FlexConnect, but all of them need to be connected to a switch and have connectivity back to the vWLC.
Here is a good quick guide:
http://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/7-6/b_1532_dg/b_1532_dg_chapter_01.html#topic_B2ABC5EE8C234517956D9B4C049A3713
-Scott
