Hello people,
I've just read that the 1550 APs are not compatible with any PoE other than their own injector.
I was already considering an 8 port HWIC for a 2901 ISR to which connecting them.
I've already requisitioned the individual injectors for the APs, but do you think I will have an issue connecting the injectors to this PoE HWIC? (Can't I just disable the PoE feature on each port?)
