05-14-2018 07:17 PM - edited 07-05-2021 08:37 AM
Hi Guys,
I am currently trying to setup a MESH toplogy involving 2 x 1562E outdoor APs, 1 WLC 3504 and 2.4Ghz Omnis and 5Ghz directional antennas.
The issue I am having is when configuring the Antenna Band Mode from "Dual" to "Single"
From the following post (https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvg35226/?rfs=iqvred), I understand that I need to downgrade the APs software version from 8.5.103.0 to 8.4.100.0 but how is this done via the WLC?
The way that I found on how to login to the WLC, goto Wireless tab, then on the left menu under "Access Points", select "Global Configuration", scroll to the bottom of the page, and select "Download Backup" which in my case points to the software version 8.4.100.0 for the APs. I then save the WLC configs and perform a graceful restart from the GUI. When the WLC gets back online, I can see the original software version associated with the APs but then after 5mins, the WLC pushes the version 8.5.103.0 back to the APs.
Any help is most welcome.
KS
05-14-2018 09:13 PM - edited 05-14-2018 09:18 PM
Yes, you have to downgrade WLC software as APs getting image from WLC. Then you can fix it as per the bug description. Downgrade process is same as upgrade process. Refer release notes for more detail.
Here is CLI method, if you prefer that
https://mrncciew.com/2013/03/14/downgrading-wlc-software/
Once fix, you can upgrade to 8.5.120.0 (Do not use 8.4.100. 0 as it is one step release, not more update on 8.4.x)
Rasika
*** Pls rate all useful responses ***
05-14-2018 09:58 PM
Hi Rasika,
Thank you for your reply.
Thanks for helping.
KS
05-14-2018 10:48 PM
Hi Kevin,
(2504-WLC) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.3.102.0
Rasika
05-15-2018 08:56 PM
05-15-2018 10:43 PM
AP usually get recovery images, once it boot, it always sync with WLC software version. So even if we get AP boot on 8.4.100.0, once it register to WLC it will upgrade to 8.5.103.0.
I would suggest you to talk to local Cisco AM or partner that you bought these product and explain your issue. They may be able to provide you right software to fix your issue.
Rasika
