Showing results forĀ
Search instead forĀ
Did you mean:Ā
1602 AP doesn't join my backup vWLC
anida0001
Hi everyone,
I have a problem with my vWLC and AP 1602. I have the  vWLC 1 with 7.4.121. software in cloud and 3 AP's 1602 and it is working fine. And I tried to make a Backup Controller vWLC 2 on Local network. I downloaded the cfg file, changedn the IP adress and uploaded on my new vWLC 2 with 8.0.100.0 software. The vWLC 2 picked up the  VLANs and it has same configuration like the  vWLC 1 but it can't see AP's..
Did anybody have a similar problem and managed to fix it?
Rasika Nayanajith
Did you try to go for individual AP (if it is registered to vWLC1) & then change the Primary & Secondary controller information under High Availability tab?
Make vWLC2 as primary & vWLC1 as secondary.
Rasika
**** Pls rate all useful responses ****
Yes, I did that.
When I checked statistics of "AP join", I saw that the  vWLC 2 reciveid  requests from AP's and then vWLC 2 sent response to AP's but still  AP's didn't join to vWLC 2. I think that the problem is new version of software(8.0.100.0) on my vWLC 2 whose software supports 15.3.3 IOS version of AP's , but on my  AP's  is  still 15.2.2 version  ( because the software 7.4.121.0 on my vWLC 1 supports  that version of AP's  IOS).
I dont know what should be my next step?
Pls attach a console output of a AP (one of the one you set vWLC2 as primary) when it power cycle. That will tell us why it cannot register to vWLC2
Rasika
