1602i not joining wlc 5508 after converting
shari1001
hello
i convert 1602i to lightweight but didn't join WLC 5508
the ap has IP  and it can ping the wlc
but the WLC cannot ping ap or i can't see the ap join stats
wlc : show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.0.121.0
Bootloader Version............................... 1.0.1
Field Recovery Image Version..................... 6.0.182.0
Firmware Version................................. FPGA 1.3, Env 1.6, USB console 1.27
Build Type....................................... DATA + WPS
System Name...................................... active
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
Redundancy Mode.................................. SSO
IP Address....................................... 10.0.0.0
IPv6 Address..................................... ::
Last Reset....................................... Software reset
System Up Time................................... 2 days 22 hrs 2 mins 59 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
--More-- or (q)uit
Configured Country............................... Multiple Countries:DE,US
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +40 C
External Temperature............................. +23 C
Fan Status....................................... OK
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 4
Number of Active Clients......................... 101
Burned-in MAC Address............................ E0:2F:6D:5D:CA:00
Power Supply 1................................... Present, OK
Power Supply 2................................... Absent
Maximum number of APs supported.................. 500
System Nas-Id.................................... -active
WLC MIC Certificate Types........................ SHA1
nv_done: unable to open "flash:/private-multiple-fs.new"
*Jan 7 10:35:27.999: %LWAPP-3-CLIENTERRORLOG: flash:/configs directory creation failed
*Jan 7 10:35:27.999: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrectsh led state 255
*Jan 7 10:35:27.999: Write of the Private File nvram:/lwapp_ap.cfg Failed on load, RCA needed
*Jan 7 10:35:28.003: Write of the Private File nvram:/lwapp_ap.cfg Failed on load, RCA needed
*Jan 7 10:35:28.003: lwapp_cfg_save_process_q - cfg file save error
*Jan 7 10:35:28.003: bsnInitRcbSlot: slot 0 has venus radio(UNSUPPORT)
*Jan 7 10:35:28.003: bsnInitRcbSlot: slot 1 has venus radio(UNSUPPORT)
*Jan 7 10:35:28.003: bsnInitRcbSlot: Slot 1 has same radio type as slot 0. Disabling radio in slot 1.
*Jan 7 10:35:28.007: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
*Jan 7 10:35:28.007: %CAPWAP-3-ERRORLOG: Failed to load configuration from flash. Resetting to default config
*Jan 7 10:35:28.011: %LWAPP-3-CLIENTERRORLOG: flash:/configs directory creation failed
*Jan 7 10:35:28.011: bsnUnlockDevice: not bring radio up: radio 0 is in admin disable state
*Jan 7 10:35:28.011: bsnUnlockDevice: not bring radio up: radio 1 is in admin disable state
*Jan 7 10:35:28.027: Interface Dot11Radio0: not starting because stop-on-failure set
*Jan 7 10:35:28.027: Interface Dot11Radio1: not starting because stop-on-failure set
*Jan 7 10:35:28.031:
10 Replies 10
Sandeep Choudhary
paste the output of this command: sh version from AP.
Reboot AP and paste the complete bootup process logs here.
Dont forget to rate helpful posts
show ver
Cisco IOS Software, C1600 Software (AP1G2-K9W8-M), Version 15.2(2)JA1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Wed 23-Jan-13 13:15 by prod_rel_team
ROM: Bootstrap program is C1600 boot loader
BOOTLDR: C1600 Boot Loader (AP1G2-BOOT-M) LoaderVersion 15.2(2)JAX, RELEASE SOFTWARE (fc1)
AP7c69.f6e1.c7fa uptime is 3 minutes
System image file is "flash:/ap1g2-k9w8-mx.152-2.JA1/ap1g2-k9w8-mx.152-2.JA1"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP1602I-E-K9 (PowerPC) processor (revision B0) with 98294K/32768K bytes of memory.
Processor board ID FGL1730S6ME
PowerPC CPU at 533Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 3.0.51.0
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 7C:69:F6:E1:C7:FA
Part Number : 73-14671-04
PCA Assembly Number : 000-00000-00
PCA Revision Number :
PCB Serial Number : FOC172850U0
Top Assembly Part Number : 800-38552-01
Top Assembly Serial Number : FGL1730S6ME
Top Revision Number : A0
Product/Model Number : AIR-SAP1602I-E-K9
Configuration register is 0xF
error:
*Jan 10 09:10:18.471: %PKI-3-SOCKETSELECT: Failed to select the socket.Peer certificate verification failed 001A
*Jan 10 09:10:18.471: %CAPWAP-3-ERRORLOG: Certificate verification failed!
Either you Did not set the correct time on WLC ? or MIC certificate of AP is expired.!!
i am sure  the time is correct on WLC
so i have to convert the ap  back to SAP ?
No, It will work with this WLC.
Can you paste the output of this command from AP:
1. Enable debug by using this command: debug capwap console cli
2. sh crypto pki certificates and paste the output here.
example:
AP#debug capwap console cli
AP# sh crypto pki certificates
no output
I upload attachment file for the bootup process
Leo Laohoo
I have seen this error message before.
Console/Telnet/SSH into the AP and look at the flash for "event.r0" &/or "event.r1".
Open them up and you should see something like this:
Radio stopped due to external code download failed
Number of supported simultaneous BSSID on Dot11Radio0: 16
Carrier Set:  () (-E)
Notice that Carrier Set is a BLANK?  This is the cause as to why the APs radio won't join the controller:  The controller sees the AP to have an invalid (BLANK = invalid) Regulatory Domain.
The reason why the radios get an invalid Regulatory Domain is because the FW of the radios get corrupted during bootup.
And this is evident the radio(s) firmware got corrupted with the bootup file ("ap_booting.txt", below) by the presence of the following lines:
*Mar  1 00:00:14.011: %DOT11-2-RESET_RADIO: Restarting Radio interface Dot11Radio0 due to get code failed: firmware file not found
*Mar  1 00:00:14.127: %DOT11-2-RESET_RADIO: Restarting Radio interface Dot11Radio1 due to get code failed: firmware file not found
shari1001
it works..
the ap has join WLC after I push the mood button for 30 sec
thank you all for you replies
Great. Happy for you that finally it worked.
