1815W Mobility Express LAN ports
ABSc
Hi all,
Somebody knows if its possible to configure 1815W LAN ports (LAN1 to LAN3) in a Mobility Express deployment?
Hello @ABSc
Honestly did not try. But using experience and best judgment, I don't think so otherwise this would be some kind of bridging network and not flexconnect as mobility express is.
 I don't have documentation saying does not support but someone got this answer via TAC:
https://supportforums.cisco.com/t5/getting-started-with-wireless/1810w-switchports-on-mobility-express/td-p/3031905
Hello Flavio,
Thanks for the info.
I was unable to find how to config LAN ports on cisco website. I suppose that Mobility Express will be for poor deployments with minimal requirements (even in this scenario, i believe that will not work as expected...).
I will see how to config this LAN port in a controlled based deployment, if possible.
Once again, thanks.
