1841 and hwic 802.11 problem accessing web
nemiath76
Ok guys i need some help. I do not possess the necessary skill yet to troubleshoot this so there it goes..
I am trying to setup a 1841 with adsl and wireless wic for home use. After endless hours (i am currently studying for ccna so i am a newbie)
of reading i managed to create a configuration that seemed to me working but its not. The problem is with the wireless connections.
There seems to be an issue with most of the requests http for example, while other requests work fine. For example via http i can access youtube but
cant access other sites. Like a request timeout. Clients that are connected to the router via ethernet work fine.
Can someone check my configuration and let me know where have i messed it up?
! Last configuration change at 12:10:12 Athens Fri Dec 2 2011 by admin
! NVRAM config last updated at 12:09:22 Athens Fri Dec 2 2011 by admin
version 12.4
service password-encryption
hostname Router
boot-start-marker
boot-end-marker
no logging buffered
enable secret 5 $1$89xj$p33gqt4Pc6UzSLKK0VR8a.
no aaa new-model
resource policy
clock timezone Athens 2
clock summer-time Athens date Mar 30 2003 3:00 Oct 26 2003 4:00
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.2.1
ip dhcp excluded-address 192.168.2.254
ip dhcp excluded-address 192.168.1.1
ip dhcp pool cisco
   network 192.168.2.0 255.255.255.0
   dns-server 192.168.2.254
   default-router 192.168.2.254
ip dhcp pool ps3
   network 192.168.1.0 255.255.255.252
   default-router 192.168.1.1
   dns-server 192.168.1.1
ip dhcp pool wireless
   network 192.168.0.0 255.255.255.0
   dns-server 192.168.0.254
   default-router 192.168.0.254
   lease 3
vpdn enable
username admin privilege 15 password 7 15165801542939702B2A
bridge irb
interface FastEthernet0/0
ip address 192.168.2.254 255.255.255.0
ip nat inside
no ip virtual-reassembly
ip tcp adjust-mss 1452
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.1.1 255.255.255.252
ip nat inside
duplex auto
speed auto
interface ATM0/0/0
no ip address
no atm ilmi-keepalive
bundle-enable
dsl operating-mode auto
interface ATM0/0/0.1 point-to-point
no ip proxy-arp
no snmp trap link-status
pvc 8/35
  pppoe-client dial-pool-number 1
interface Dot11Radio0/1/0
no ip address
no ip redirects
ip local-proxy-arp
encryption vlan 1 mode ciphers tkip
ssid Osiris
    vlan 1
    authentication open
    authentication key-management wpa
    guest-mode
    wpa-psk ascii 7 13111F43185D177E3B703B2022720103
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
no cdp enable
interface Dot11Radio0/1/0.1
encapsulation dot1Q 1 native
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0/1/1
no ip address
shutdown
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
station-role root
interface Dialer1
description $FW_OUTSIDE$
mtu 1492
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
ppp authentication chap pap callin
ppp chap hostname kkouts
ppp chap password 7 000816010B095B5656
ppp pap sent-username kkouts password 7 10420C1E0A45425B55
ppp ipcp dns request
interface BVI1
ip address 192.168.0.254 255.255.255.0
ip nat inside
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
ip http authentication local
no ip http secure-server
ip dns server
ip nat inside source list 1 interface Dialer1 overload
ip nat inside source static udp 192.168.2.4 60000 interface Dialer1 60000
ip nat inside source static tcp 192.168.2.4 60000 interface Dialer1 60000
access-list 1 permit 192.168.0.0 0.0.255.255
dialer-list 1 protocol ip permit
no cdp run
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
exec-timeout 0 0
password 7 00071A150754
logging synchronous
line aux 0
line vty 0 4
password 7 141341065C07387F2731
login local
scheduler allocate 20000 1000
end
nemiath76
Also the output from wireshark returns a lot of
"Duplicate to the ACK.."  messages.
Ok here is an update. As you can see the MTU is set to 1492 for the Adsl Interface.
After manually setting the mtu size in my macbooks wireless card it started to work fine.
Now here is the question. Shouldnt the cisco wireless interface have a setting that would automatically
do that for the clients? Macbook has an auto MTU size which works fine with the Ethernet interfaces of the router.
Is there a way to set the MTU for the cisco wireless?
