2.4 GHz. Frequency setting.
alikoca869453
Community Member
There are 11 access points in the system. The distance between them is 80 mt. only the difference between 3 of them 450 mt. 2.4 MHz. Signals between operating devices are low. The current frequency settings are as shown in the picture. how the settings should be.
19 Replies 19
Mark Elsen
 - Don't know why you are using Custom for Rf Channel Assignment and Tx Power Level Assignment - use Global.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
When global, the signal is low.
I want to learn, antenna gain dbi  and
Why are the channel and power settings statically assigned?
Is ED-RRM enabled?
Thanks for answer
This is done because the signal levels of the devices running 2.4 MHz are low.
What is your suggestion?
What is ED-RRM? how we should make this setting ?
My recommendation is to set the AP's channel selection and power selection to auto.
Go to RRM and DCA and make sure they are set to auto.
hi
What should be the antenna gain setting?
As you say, when I want to change the frequencies in the dca channel list section gives the following error.
dca screen is as follows. What are your suggestions
What AP do you have? Why are you adjusting the antenna gain?
What exactly are you trying to do?
What AP do you have?              AIR-AP1562E-E-K9
Why are you adjusting the antenna gain?            Signal levels come low for 2.4mghz devices
exactly what I want to do is to raise the signal levels of the devices and ensure that they do not break.
a value must be entered here.
What is your suggestion.
Ok, so if you have a 1562E what model of antenna are you using?
AIR-ANT2513P4M-N 13 dbi  (There are 2 units and there is a distance of 800 meters between them.)
AIR-ANT2568VG-N 8 dbi    ( There are 8 units and there is a distance of 50 meters between them.
Have you done any site survey?
How are you measuring the signals provided by the antennas?
Cheers,
Vasco
