09-04-2009 05:37 AM - edited 07-03-2021 06:00 PM
After I reset the controller to factory defaults and go through the CLI config wizard, the mgmt ports (no matter which one i assign) do not work. I can not ge to the GUI after if i do a config network webmode enable. I can see the IP address through the router, but can not even ping it. Any ideas?
Solved! Go to Solution.
09-04-2009 07:23 AM
Are you bychance tagging the vlan for the management port? If so, set vlan 0 for the mgmt port and see if you can connect to it now (assuming you are plugged into a tagged access port, or are setting the native vlan on the switchport to the controller to be that vlan you want the controller in).
If you have it set for vlan 0, and you plug directly into that port and assign an IP address static in the mgmt subnet, can you talk to it that way?
09-04-2009 07:23 AM
09-04-2009 07:48 AM
I just set the vlan to 0 (untagged) and configured port 1 for management, set an IP and i can ping it beautifully through cmd.
I then reset it, set the vlan to 5 and configured port 5 for management and can not ping it.
I guess for what we are using it, we don't necessarily need to have a tagged vlan, but if I did need it, what would I have to do to make that work?
Thanks for the fix, we can now move on to the next step.....
09-04-2009 09:49 AM
Setting the vlan as 0 will "untag" that interface.
If you set your switch as "access vlan 5" or "native vlan 5", then the switch is sending VLAN 5 traffic untagged.
So, if you want the MGMT to be tagged as vlan 5, then you need to have your trunk port configured with something other than 5 as the native. The traffic will still be in vlan 5 when set to 0, but it is the switch that then tags this traffic across your network.
If you are not trunking vlans, you don't need to define a vlan, and 0 will work great.
