09-30-2011 03:34 PM - edited 07-03-2021 08:51 PM
I have a 2106 WLC with 4 AP's (AIR-LAP1252AG-A-K9)
One of the AP's (port 4) is only connecting at 10Mbps, not 100Mbps and I don't know why?
All the ;ports are set on the controller to AUTO, When I try to force that port to 100Mbps, the link drops.
Could it be a cabling issue... or could I have a bad port on the 2106? How to I troubleshoot this. It's odd, because
that particular AP is about 100ft from thte WLC and the closest to it.
Any ideas?
Joe
Primary Software Version 7.0.116.0
Predownload Retry Count
Boot Version 12.4.18.1
IOS Version 12.4(23c)JA2
Mini IOS Version 3.0.51.0
09-30-2011 03:44 PM
I tried moving the AP plugged into port 4 over to port 6 and it didn't make a difference.
09-30-2011 06:22 PM
Have you tried replacing the patch cable?
10-04-2011 09:04 AM
Interesting... I unplugged the LAP (data and power) and removed it from the wall of our training room 75ft from our computer room, walked the AP into the computer room and with a 15' patch cord and power supply plugged it back into the WLC 2106. Waited a min for the AP to reboot and now my port speed is showing 100Mbps connection.
The issue must be with the cable run...? Thanks for pointing out the obvious. This now begs another questions regarding 2106 best practices and the idea of connecting our 4 AP's directly into network switches and not the WLC 2106 itself. That seems to be the recommendation. Any comments?
Joe
10-04-2011 02:30 PM
The ports of the 2000/2100 weren't meant for direct connection to AP but to the switches. What the PoE ports are for is beyond my imagination.
10-19-2011 09:25 AM
Problem solved. Was a cabling punchdown issue. Fixed and relocated AP back into it's original location in the training room and it connected just fine at 100Mbps. Green/White wire loose. Thanks for the feedback.
10-19-2011 02:51 PM
May I ask if you can mark this thread as "Answered" please?
10-19-2011 03:08 PM
Will do.
Sent via BlackBerry by AT&T
