tsmarcyes
Level 4
Level 4
Does the 2106 support local eap authentication (leap, peap, etc..)
andrew.prince
Level 11
Level 11
Timothy,
Here is the 2106 data sheet - should tell you everything you need to know:-
http://www.cisco.com/en/US/prod/collateral/wireless/ps6302/ps8322/ps7206/ps7221/product_data_sheet0900aecd805aaab9.html
HTH.
It depends on the code you have on your WLC. I believe 4.2 supports local EAP. This however doesn't give you what a radius server can provide.
-Scott
