2500 wireless guest anchor, dhcp performance
gnijs
Level 4
Level 4
I just read that starting from version 7.4, the 2500 controller can be used to terminate guest anchor tunnels.
This is great news, but i have a question regaring the performance of the internal DHCP server when used in guest environments.
Can it be used and if so, what is its performance ? (ie requests / second)
regards,
Geert
Scott Fella
Take a look at the data sheet and it will give you a general understanding of the max client count which is 500 and the throughput which is 500mbps unless you run 7.4 and have LAG enabled which gives you 1gig.  I would only use this for small installs and if its a pretty medium to large guest network, then stick with the 5508.
http://www.cisco.com/en/US/prod/collateral/wireless/ps6302/ps8322/ps11630/data_sheet_c78-645111.html
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
