2504 as anchor controller
johannesluther
Community Member
today I have a quite simple question. I want to use a 2504 WLC as guest anchor controller in a DMZ.
Until now I only deployed 2504 in LAG/Etherchannel configuration, so I'm unsure if my plan works:
I need to have different physical interfaces for the encapsulated EoIP traffic and the actual decapsulated guest traffic.
So I want to have something like this:
Management Interface: VLAN 10 / assigned to port 1 and backup port 2
Dynamic Interface: VLAN 11 / assigned to port 3 and backup port 4
I understand that there is a document with a few use cases:
http://www.cisco.com/en/US/products/ps11630/products_tech_note09186a0080b8450c.shtml
But no of these cases really matches my requirements.
Is my design a possible and supported solution?
Of course the redundant switches on WLC port 1 and 2 share one common layer-2 subnet. The same is the case for port 3 and 4.
Thanks in advance!
Best regards
Johannes
Stephen Rodriguez
yes that will work.  So long as you are not running LAG you can split your ports.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
