2504 Controller Decrypt errors occurred for client
Hello all,
I ‘have deployed CT 2504 and CAP 1600 wireless solution, and I'm facing issue with same wireless clients.
I have this message error:
"Decrypt errors occurred for client 00:23:xx:xx:xx:xx using WEP key on 802 interface of AP bc:xx:xx..."
The Controller is running 7.6.130 version.
Did you encounter this issue? Please suggests the solution
I’ll appreciate
Cheers
Rasika Nayanajith
Migrate your WLAN to use WPA2/AES, WEP is no longer treated as a secure protocol
Rasika
