2504 wlc web authentication
Scott Raley
I have a 2504 WLC currently in place hosting 6 CAP's. Are there good instructions on setting up the web authentication piece? I have a Windows 2008 server that runs IIS on it. I have found basic information about the 4400 but nothing specific about the 2504. Also where do I get this software? The 2504 documentation online talks about the steps but I don't see a software download. Thanks
Sandeep Choudhary
Just check this procedure:
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wlan-security/69340-web-auth-config.html
I hope you have WLC software 7.0.x(This is first support ofr this wlc) then u do need any other software.
Dont forget to rate helpful posts
