256 bit encryption on 1300 bridge link?
johowell
Customer requires 256 bit encryption on wireless LAN bridge link. 1300 Bridge Data Sheet states that the 1300 bridge supports "AES (802.11i)". How can I determine if 256 bit encryption is included in the 1300 "AES (802.11i)" security support?
bcolvin
Level 3
Level 3
Joe
as far as i am able to determine the 1300 AES-CCMP encryption is 128bit. reference the following links.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008054339e.shtml#conv
http://www.cisco.com/en/US/prod/collateral/wireless/ps5678/ps430/prod_qas0900aecd801e3e59.html
Know this doesn't solve you peoblem. you may have to set up a VPN with the required encryption.
Bill
