2602i Led control
JOHN GRIMM
Community Member
Is it possible to control the LED on a 2602i?  It's too bright.
Rasika Nayanajith
You can turn it off if that helps. Otherwise I do not think you can control light level. Here is the CLI command to do this for a given AP
(WLC3) >config ap led-state ?
disable        Disables the LED-State for an AP
enable         Enables the LED-State for an AP
(WLC3) >config ap led-state disable ?
all            Applies the configuration to all connected APs.
     Enter the name of the Cisco AP
Rasika
**** Pls rate all useful responses ****
Leo Laohoo
It's too bright.
Nope.  You can either turning it on, off or flashing.  Your choice.
Scott Fella
Turn it off or else put one of these on the light like one of my customers did:)
http://m.staples.com/touch/product.html#67076
-Scott
