2802i 5Ghz Radio not broadcasting
JafferStroks
Im trying to setup a 2802i to do a AP on a Stick Survey. I converted the AP to Mobility Express 8.10.152. I went through a fresh setup and assigned an SSID to both radios. It is only broadcasting from the 2.4.
I tried creating a new SSID and assigned it to the 5Ghz radio and still see nothing in the air.
I even deleted all WLANs and created one just on the 5GHz radio and no luck.
I have factory reset it at least 3 times and did all the same things and no luck.
When i run the show advanced 802.11a txpower it shows the radio enabled and at the power level I set in the GUI.
I can change the power level in the GUI and see it change from the cli.
No idea what is going on with it so any suggestions would be hugely appreciated.
Arshad Safrulla
Nothing can be said without having a look in to the show commands and OTA captures. But by the looks of it sounds more like a hardware issue, is it possible to get TAC check this?
marce1000
 - Reboot the AP , and check the logs just after startup , you may find more info's related to this problem.
 M.
