2802i is enable to join Controller
Hamza DEHAL
I have a 2802i as a Mobility Express Controller with 5 APs (2800 and 1830 Capwap and ME), I am trying to add another 2802i but it can't joun the controller.
I tried to upgrade the AP to the same version as the controller (8.10.130.0) when I use the command: ap-type mobility-express tftp://IP@/image_name.tar it says : image upgrade not needed (same thing with .zip file)
I used: archive download-sw /reload tftp://IP@/image_name
This time it starts uploading the image and when it reaches 100% it replies with an ERROR!
Any help would be much appreciated.
15 Replies 15
Hamza DEHAL
Before even with a tftp server image it failed, I resolved the problem by resetting the AP and reloading the controller.. the image upgraded as magic.
Thank you all for your replies
