2802i U-Boot issue
craiglebutt
Level 6
Level 6
Have 20+ 2802I with U Boot issue on a 5520WLC, have tried booting from different partition, but still the same.
Capture shows this, so not sure if corrupted.  But just keeps going round and round.
These are not under support, have seen Solved: 2802i AP blank NAND, how to recover? - Cisco Community but before I try this, want to see if there is a different way to fix
BootROM: Boot image signature verification PASSED
____ _
/ ___|(_) ___ ___ ___
| | | |/ __| / __|/ _ \
| |___ | |\__ \| (__| (_) |
\____||_||___/ \___|\___/
_ _ ____ _
| | | | | __ ) ___ ___ | |_
| | | |___| _ \ / _ \ / _ \| __|
| |_| |___| |_) | (_) | (_) | |_
\___/ |____/ \___/ \___/ \__|
** LOADER **
U-Boot 2013.01-ge1c49d93a (Jul 28 2023 - 09:08:14) SDK version: 2015_T2.0p10
Board: Barbados-2K
SoC: MV88F6920 Rev A1
running 2 CPUs
CPU: ARM Cortex A9 MPCore (Rev 1) LE
CPU 0
CPU @ 1800 [MHz]
L2 @ 900 [MHz]
TClock @ 250 [MHz]
DDR4 @ 900 [MHz]
DDR4 32 Bit Width,FastPath Memory Access, DLB Enabled, ECC Disabled
DRAM: 1 GiB
RST I2C0
NAND: ECC 4bits, 256 MiB
SF: Detected MX25L3205D with page size 64 KiB, total 4 MiB
PCI-e 1 (IF 0 - bus 0) Root Complex Interface, Detected Link X1, GEN 2.0
PCI-e 2 (IF 1 - bus 1) Root Complex Interface, Detected Link X1, GEN 2.0
Map: Code: 0x3fed7000:0x3ffad848
BSS: 0x3ffef314
Stack: 0x3f9c6f20
Heap: 0x3f9c7000:0x3fed7000
U-Boot Environment: 0x00100000:0x00110000 (SPI)
Board configuration:
| port | Interface | PHY address |
| egiga1 | SGMII | 0x01 |
| egiga2 | SGMII | 0x00 |
Net: , egiga1, egiga2 [PRIME]
Hit ESC key to stop autoboot: 0
u-boot>printenv boot
## Error: "boot" not defined
u-boot>> setenv BOOT part1
u-boot>> saveenv
Saving Environment to SPI Flash...
Erasing SPI flash....Writing to SPI flash.....done
u-boot>> boot
Creating 1 MTD partitions on "nand0":
0x000000200000-0x000010000000 : "mtd=2"
UBI: attaching mtd1 to ubi0
UBIFS: mounted UBI device 0, volume 0, name "part1"
Loading file 'part1/info.ver' to addr 0x02000000 with size 84 (0x00000054)...
Done
Loading file 'part1/part.bin' to addr 0x02000000 with size 6387269 (0x00617645)...
Done
Checking image signing.
Image signing verification success, continue to run...
Preferred boot heartbeat count: 1
## Booting kernel from Legacy Image at 02000000 ...
Image Name: Barbados Firmware Image
Created: 2024-05-10 5:14:29 UTC
Image Type: ARM Linux Multi-File Image (uncompressed)
Data Size: 6386261 Bytes = 6.1 MiB
Load Address: 00008000
Entry Point: 00008000
Contents:
Image 0: 4204528 Bytes = 4 MiB
Image 1: 2165579 Bytes = 2.1 MiB
Image 2: 16137 Bytes = 15.8 KiB
Verifying Checksum ... OK
## Loading init Ramdisk from multi component Legacy Image at 02000000 ...
## Flattened Device Tree from multi component Image at 02000000
Booting using the fdt at 0x0261338c
Loading Multi-File Image ... OK
OK
reserving fdt memory region: addr=0 size=4000
Loading Device Tree to 01ff9000, end 01ffff08 ... OK
Starting Device Tree update ('fdt_skip_update' = no)
Limit DDR size at 3GB due to power of 2 requirement of Address decoding
Updating device tree successful
Starting kernel ...
[01/01/1970 00:00:00.0000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 260096
[01/01/1970 00:00:00.0000] Memory: 1025724K/1048576K available (5743K kernel code, 411K rwdata, 2508K rodata, 359K init, 496K bss, 22852K reserved, 0K highmem)
[01/01/1970 00:00:00.1200] CPU1: Booted secondary processor
[01/01/1970 00:00:01.4600] buginf tty flushing thread started, ttyport=bf2aec00
[01/01/1970 00:00:01.5800] m25p80 spi1.0: found mx25l3206, expected n25q032
[*01/01/1970 00:00:02.7517] buginf() enabled.
[*01/01/1970 00:00:02.7614] Made it into bootsh: May 10 2024 05:06:54 T-e0550ad380a1f81adf839cc9111f3a6bf79904ff-ge0550ad3-aut
[*01/01/1970 00:00:10.8829] bootsh mini ramfs booted /bootpart/part1/ramfs_data_cisco.cpio.lzma
Welcome to Cisco.
[*01/01/1970 00:00:32.4646] /init: ioctl(SIOCGIFHWADDR): wired0: No such device
[*01/01/1970 00:00:32.4677] /init: ioctl(SIOCGIFHWADDR): wired0: No such device
[*01/01/1970 00:00:32.5831] /init: ioctl(SIOCGIFHWADDR): wired0: No such device
[*01/01/1970 00:00:32.5861] /init: ioctl(SIOCGIFHWADDR): wired0: No such device
[ OK ] Reached target Cisco File Systems (Pre).
[ OK ] Reached target Timers.
[ OK ] Created slice -.slice.
[ OK ] Listening on udev Kernel Socket.
[ OK ] Listening on udev Control Socket.
[ OK ] Listening on Delayed Shutdown Socket.
[ OK ] Reached target Sockets.
[ OK ] Created slice system.slice.
Starting Cisco UBIFS reformat/mount...
Starting udev Coldplug all Devices...
[ OK ] Reached target Slices.
[ OK ] Created slice system-sshd\x2dkeygen.slice.
Starting udev Kernel Device Manager...
[ OK ] Created slice system-serial\x2dgetty.slice.
[ OK ] Started Cisco UBIFS reformat/mount.
[ OK ] Started udev Kernel Device Manager.
Starting Cisco early mount...
[ OK ] Started Cisco early mount.
[ OK ] Reached target Local File Systems (Pre).
Starting Cisco system time setup...
Starting Cisco platform file generation...
Starting Cisco seed generation...
[*02/22/2019 23:59:59.0759] Last reload time: Apr 8 05:54:02 2025
[*04/08/2025 05:54:02.0003] Setting system time Tue Apr 8 05:54:02 UTC 2025
Starting Cisco fips check...
[ OK ] Started Cisco system time setup.
[ OK ] Started Cisco seed generation.
[ OK ] Started Cisco fips check.
[ OK ] Started Cisco platform file generation.
Starting Cisco btldr service...
[ OK ] Started Cisco btldr service.
[ OK ] Started udev Coldplug all Devices.
[ OK ] Reached target Local File Systems.
Starting Cisco act2 check...
[*04/08/2025 05:54:03.6209] GCM-128 POST passed
[*04/08/2025 05:54:03.6209] G[ OK ] Started Cisco system time saving.
Starting Cisco system time saving...
Starting Security Auditing Service...
[*04/08/2025 05:54:05.1745] parameter passed without an option given
Starting Cisco pkg install service...
Starting Cisco S10 boot service...
[ OK ] Started Security Auditing Service.
[04/08/2025 05:54:06.6200] PCI: enabling device 0000:00:02.0 (0140 -> 0143)
[04/08/2025 05:54:06.7000] PCI: enabling device 0000:02:00.0 (0140 -> 0142)
[ OK ] Started Cisco pkg install service.
[04/08/2025 05:54:12.9900] PCI: enabling device 0000:00:03.0 (0140 -> 0143)
[04/08/2025 05:54:13.0700] PCI: enabling device 0000:03:00.0 (0140 -> 0142)
[ OK ] Stopped target Timers.
[ OK ] Removed slice system-serial\x2dgetty.slice.
[ OK ] Removed slice system-sshd\x2dkeygen.slice.
[*04/08/2025 05:54:05.6023] 43
[*04/08/2025 05:54:05.8891] Active version: 8.10.196.0
[*04/08/2025 05:54:05.8921] Backup version: 8.10.185.0
[*04/08/2025 05:54:06.3909] device wired0 entered promiscuous mode
[*04/08/2025 05:54:06.7939] wifi0: Initializing TX ring
[*04/08/2025 05:54:06.8030] wifi0: prepare firmware downloading
[*04/08/2025 05:54:07.6239] wifi0: Firmware downloading
[*04/08/2025 05:54:08.8450] 0;<30>systemd[1]: Started Cisco pkg install service.
[*04/08/2025 05:54:09.3549] 0;0;0;0;0;0;0;
[*04/08/2025 05:54:12.5429] Firmware download complete
[*04/08/2025 05:54:12.7349] wifi0: Getting HW specs. Retrying for 3
[*04/08/2025 05:54:12.7352] Mac_Init
[*04/08/2025 05:54:12.7356] Preparing to set HW specs
[*04/08/2025 05:54:12.7358] FIPS enc aes-ccmp Verified
[*04/08/2025 05:54:12.7359] FIPS dec aes-ccmp Verified
[*04/08/2025 05:54:12.7360] FIPS enc aes-ccmp-256 Verified
[*04/08/2025 05:54:12.7361] FIPS dec aes-ccmp-256 Verified
[*04/08/2025 05:54:12.7362] FIPS enc aes-gcmp Verified
[*04/08/2025 05:54:12.7364] FIPS dec aes-gcmp Verified
[*04/08/2025 05:54:12.7365] FIPS enc aes-gcmp-256 Verified
[*04/08/2025 05:54:12.7366] FIPS dec aes-gcmp-256 Verified
[*04/08/2025 05:54:13.1573] wifi1: Initializing TX ring
[*04/08/2025 05:54:13.1654] wifi1: prepare firmware downloading
[*04/08/2025 05:54:13.9855] wifi1: Firmware downloading
[*04/08/2025 05:54:15.0057] ... rebooting now!
[*04/08/2025 05:54:15.2069] 0;0;0;0;[ OK ] Stopped target Sockets.
[ OK ] Stopped target Slices.
Stopping Cisco system time saving...
<30>systemd[1]: Removed slice system-sshd\x2dkeygen.slice.
[*04/08/2025 05:54:16.8847]
[*04/08/2025 05:54:16.8847] Writing reload timestamp (Tue Apr 8 05:54:16 UTC 2025) to disk
Stopping Securit[04/08/2025 05:54:17.1600] audit_printk_skb: 36 callbacks suppressed
[*04/08/2025 05:54:17.2489] 0;[ OK ] Stopped Cisco pkg install service.
Stopping Cisco pkg install service...
[ OK ] Stopped Cisco act2 check.
[ OK ] Stopped Security Auditing Service.
[ OK ] Stopped Cisco system time saving.
[ OK ] Stopped Cisco S10 boot service.
[ OK ] Stopped target Local File Systems.
Unmounting /firmware...
<30>systemd[1]: Stopped Cisco pkg install service.
[*04/08/2025 05:54:17.7626] 0;0;
[*04/08/2025 05:54:18.3489] Firmware download complete
[*04/08/2025 05:54:18.5449] wifi1: Getting HW specs. Retrying for 3
[*04/08/2025 05:54:18.5452] Mac_Init
[*04/08/2025 05:54:18.5455] Preparing to set HW specs
[*04/08/2025 05:54:18.5457] FIPS enc aes-ccmp Verified
[*04/08/2025 05:54:18.5459] FIPS dec aes-ccmp Verified
[*04/08/2025 05:54:18.5460] FIPS enc aes-ccmp-256 Verified
[*04/08/2025 05:54:18.5461] FIPS dec aes-ccmp-256 Verified
[*04/08/2025 05:54:18.5462] FIPS enc aes-gcmp Verified
[*04/08/2025 05:54:18.5463] FIPS dec aes-gcmp Verified
[*04/08/2025 05:54:18.5464] FIPS enc aes-gcmp-256 Verified
[*04/08/2025 05:54:18.5465] FIPS dec aes-gcmp-256 Verified
Unmounting /tmp...
[ OK ] Stopped Cisco fips check.
Stopping Cisco fips check...
Unmounting /storage...
[ OK ] Stopped Cisco system time setup.
Stopping Cisco system time setup...
Unmounting /sys/kernel/debug...
Stopping Cisco seed generation...
[ OK ] Stopped Cisco btldr service.
Stopping Cisco btldr service...
[ OK ] Stopped Cisco platform file generation.
Stopping Cisco platform file generation...
[ OK ] Unmounted /firmware.
[ OK ] Unmounted /tmp.
[ OK ] Unmounted /storage.
[ OK ] Unmounted /sys/kernel/debug.
[ OK ] Stopped Cisco seed generation.
[ OK ] Reached target Unmount All Filesystems.
[ OK ] Stopped target Local File Systems (Pre).
[ OK ] Stopped target Cisco File Systems (Pre).
[ OK ] Stopped Cisco early mount.
Stopping Cisco early mount...
[ OK ] Stopped Cisco UBIFS reformat/mount.
Stopping Cisco UBIFS reformat/mount...
[ OK ] Removed slice system.slice.
[ OK ] Removed slice -.slice.
[ OK ] Reached target Shutdown.
[ OK ] Reached target Final Step.
Starting Reboot...
[04/08/2025 05:54:21.5600] reboot: Restarting system
BootROM - 1.78
Booting from SPI flash, Secure mode
BootROM: RSA Public key verification PASSED
BootROM: CSK block signature verification PASSED
BootROM: Boot header signature verification PASSED
BootROM: Box ID verification PASSED
BootROM: JTAG is disabled
General initialization - Version: 1.0.0
Detected Device ID 6920
Master bootloder version 1.4a
High speed PHY - Version: 2.0
BoardId = 0x21board SerDes lanes topology details:
| Lane # | Speed| Type |
| 1 | 0 | SGMII1 |
| 2 | 5 | PCIe1 |
| 4 | 5 | PCIe2 |
| 5 | 0 | SGMII2 |
:** Link is Gen1, check the EP capability
PCIe, Idx 1: Link upgraded to Gen2 based on client cpabilities
PCIe, Idx 2: Link upgraded to Gen2 based on client cpabilities
High speed PHY - Ended Successfully
DDR4 Training Sequence - Ver TIP-0.23.(Sublib 0.8)0
DDR4 Training Sequence - Switching XBAR Window to FastPath Window
DDR4 Training Sequence - Ended Successfully
BootROM: Image checksum verification PASSED
Leo Laohoo
AP is dead.
@craiglebutt,
Please check if all the 20+ APs have the same issue.  If they have check the first seven digit of their serial numbers for a possible faulty batch.
6 Replies 6
From the logs it is trying to upgrade as it if downloading firmware. Boot is 8.10.196. what version is on the controller?
Are there other 2802s that have worked?
Some of these APs have been off line for a while, do to refurbs, not been able to gain access and may have missed a upgrade.
8.10.196.0 is what we are currently running on 5520s
aleabrahao
Meraki Community All-Star
Please note that the 5520 controller has an EOS date of January 31, 2027. Consider migrating to the C9800.
https://www.cisco.com/c/en/us/products/collateral/wireless/5520-wireless-controller/eos-eol-notice-c51-744430.html
I am not a Cisco employee. My suggestions are based on documentation of Cisco, best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
Got 9800s already, just the old thing called licences, before can migrate.
Leo Laohoo
AP is dead.
@craiglebutt,
Cheers for that, that looks like a hardware fault according to google, so should be covered under lifetime warranty, I'll run it by our account manager cheers
