340 series problem
l.monos
Community Member
I'm using two bridge wireless to send files from a pc to another 100 meter far.
we can call one pc A and pc B.
Supposing that the direction of transfering is from A to B the data rate change : 5 Mbs if the command to start copy is given from B 2.5Mbs if the command is given from A.
This thing happens in a dual way if the direction of transfer is from B to A.
Could anyone help me to understand?
kbeltz
Level 5
Level 5
Check the configuration of both bridges and make sure you do not have anything different configured on each. You may want to put the latest firmware on them just to see if that is the issue.
