How does ACU choose between SSID1 & SSID2
c.fritz
Up to 3 SSIDs can be configured for a single profile in ACU. Supposing
that 2 SSIDs are configured, and these 2 SSID are existing on the
Access Point, what is the selection process between the 2 SSIDs.
I thought that SSID1 was preferred, but during my tests it wasn't
verified.
Does somebady know ?
Thanks.
tepatel
Here is the url which explaines the use of all 3 SSID's.
http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo_350/350cards/windows/incfg/win_ch6.htm#xtocid2
The first ssid will be used get association..An optional SSIDs (SSID2 and 3) that identifies a distinct network and enables you to roam to that network without having to reconfigure your client adapter.
