350 WAP flash problems
jparis
Community Member
I have a 350 AP that at one point had IOS on it. it seems to have no files in the flash right now... i'm trying to load ios back onto it using tftp... the tftp_init command doesn't seem to do anything and i get a permission denied error when i try to tar -extract from a tftp server to the flash... is there another way to get a tar file onto the device, through xmodem directly in hyperterminal for example?
does it matter if the files are the original name? i've shortened them to easier remember them...
wong34539
Level 11
Level 11
Check this out for IOS upgrade problems.
Release Notes for Cisco Aironet Conversion Upgrade Image 2.0 for Cisco IOS Software for Cisco Aironet 350 Series Access Points
http://www.cisco.com/en/US/products/hw/wireless/ps458/prod_release_note09186a00801d8227.html
jparis
Community Member
that doesn't seem to help, i have a newer version of the bootloader on there that doesn't respond to the same commands... i have the following
C350 Boot Loader (C350-BOOT-M) Version 12.2(13)JA
TAC Support: http://www.cisco.com/tac
ap: ?
? -- Present list of available commands
arp -- Show arp table or arp-resolve an address
boot -- Load and boot an executable image
cat -- Concatenate (type) file(s)
clear_ether -- clear ethernet port statistics
clear_phy_stat -- clear phy statistics
copy -- Copy a file
delete -- Delete file(s)
dir -- List files in directories
ether_init -- initialize ethernet port
fec_speed_read -- read fec speed
fec_speed_write -- write fec speed
fec_wire_loop -- ehternet external wire loopback
flash_init -- Initialize flash filesystem(s)
format -- Format a filesystem
fsck -- Check filesystem consistency
help -- Present list of available commands
led_test -- cycle led patterns
memory -- Present memory heap utilization information
mkdir -- Create dir(s)
phy_read -- read phy register
-- MORE --
phy_status -- display phy status
phy_write -- write phy register
read -- read at address
rename -- Rename a file
reset -- Reset the system
rmdir -- Delete empty dir(s)
set -- Set or display environment variables
set_baud -- set baud rates
set_sleep -- Pause (sleep) for a specified number of seconds
show_ether -- show ethernet port statistics
show_fec_queues -- show fec queues
show_fec_reg -- display fec registers
show_packet_buf -- show packet buffers allocation
tar -- extract or listing a tar file
test ram -- read at address
tftp_init -- Initialize tftp file system
type -- Concatenate (type) file(s)
unset -- Unset one or more environment variables
version -- Display boot loader version
write -- write at address
