I will be attaching a 350 series workgroup bridge to a remote monitoring unit. The unit is powered with a solar panel and battery setup. I need to know how much current the bridge will draw to determine if I need to upgrade my solar panel. I already know the voltage range on which the bridge operates. This would help me out tremendously if somebody knows this answer. It does not seem to be on any of Cisco's technical spec sheets. Thanks.
