04-15-2013 10:53 PM - edited 07-03-2021 11:55 PM
Hi there,
Does anybody know if the Cisco 3502p AP can run as a root mesh access point ?
04-16-2013 04:37 AM
It can, but its not meant to be used as a mesh. When doing high density with a 3502p, you really need to have each wired.
04-16-2013 05:47 AM
Thanks Scott
04-16-2013 05:52 AM
No problem... your better off with the 3502 or 3602 running indoor mesh, but not in a stadium venue.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
04-22-2013 03:44 PM
I would like to inform you that it can be used as Mesh root AP. But this AP is meant for High Density areas that require the cisco High-gain Stadium Antenna. For more detail you can go through the below link.
