3600e ap AIR-ANT2524V4C-R (What is it really?)
ROBERT WATSON
AIR-ANT2524V4C-R=
Is this a directional Patch or a Omni patch
Cisco's tech spec pdf on this antenna says its
Cisco Aironet Four-Element, MIMO, Dual-Band
Ceiling Mount Omnidirectional Antenna
(AIR-ANT2524V4C-R)
with no beamwidth stats
Cisco's N antenna porfolio pdf says its directional
Antenna Product Portfolio for
Cisco Aironet 802.11n Access Points
Scott Fella
It's an omni. You can always look at the Azimuth and Elevation Plane Patterns.
-Scott
Rob Huffman
Hi Robert,
Scott is most correct here +5
The Azimuth and Elevation Plane Patterns are nicely shown in the "Tech Specs"
section of the attached doc;
http://www.cisco.com/en/US/docs/wireless/antenna/installation/guide/ant2524v4c.pdf
Cheers!
Rob
"Always movin' ahead and never lookin' back" - Springsteen
