3602 AP connectivity issues
mk
Community Member
Hi All
Busy with a rollout of a number of new 3602 APs, running into issues with some of them not coming up correctly.
DHCP for each subnet is configured on the local switch where the AP conects, the WLC is at another location.
Port configuration:
interface FastEthernet2/0/45
switchport trunk native vlan 20
switchport trunk allowed vlan 20,103
switchport mode trunk
mls qos trust cos
end
AP is connected:
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone
Device ID            Local Intrfce         Holdtme   Capability    Platform   Po
rt ID
AP4c4e.3560.389d    Fas 2/0/45            165            R T      AIR-CAP360Gig
0.1
AP has IP address:
IP address       Client-ID/              Lease expiration        Type
                 Hardware address
10.104.34.4      014c.4e35.6038.9d       Sep 27 2013 11:57 AM    Automatic
ping 10.104.34.4 - from local switch
Sending 5, 100-byte ICMP Echos to 10.104.34.4, timeout is 2 seconds:
Success rate is 0 percent (0/5)
No response....
sh cdp nei f2/0/45 det
Device ID: AP4c4e.3560.389d
Entry address(es):
  IP address: 10.104.34.4
Platform: cisco AIR-CAP3602I-E-K9   ,  Capabilities: Router Trans-Bridge
Interface: FastEthernet2/0/45,  Port ID (outgoing port): GigabitEthernet0.1
Holdtime : 127 sec
Version :
Cisco IOS Software, C3600 Software (AP3G2-RCVK9W8-M), Version 12.4(25e)JAL1, REL
EASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Mon 10-Dec-12 23:40 by prod_rel_team
advertisement version: 2
Duplex: full
Power drawn: 13.000 Watts
Power request id: 42177, Power management id: 1
Power request levels are:13000 0 0 0 0
Management address(es):
Correct MAC in table:
          Mac Address Table
Vlan    Mac Address       Type        Ports
  20    4c4e.3560.389d    DYNAMIC     Fa2/0/45
Total Mac Addresses for this criterion: 1
DHCP configuration:
ip dhcp excluded-address 10.104.34.1 10.104.34.2
ip dhcp pool Wireless-AP
   network 10.104.34.0 255.255.255.248
   default-router 10.104.34.1
   option 43 hex f104.0a49.000b
SVI configuration:
interface Vlan20
description Wireless-management
ip address 10.104.34.1 255.255.255.248
no ip redirects
no ip unreachables
From AP log:
%CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
Looks like the does not know that is has an IP address and doesn't even try.
We have this exact DHCP configuraion running at a number of locations so quite sure it works,
Tried static configuration anyway:
AP4403.a734.8e9b#sh capwap ip config
LWAPP Static IP Configuration
IP Address         10.104.34.4
IP netmask         255.255.255.248
Default Gateway    10.104.34.1
Primary Controller 10.73.0.11
Same result:
Have a few of these new 3602 doing this, out of the box.
Any ideas?
Rasika Nayanajith
Why did you configure switch port as trunk ? Are these deploy as FlexConnect or Local mode ? If possible test it just connecting to a vlan 20 access port & see.
Try "clear capwap private-config" of AP console & try it again. Take the AP console output & post it here if still not working
Rasika
