09-08-2015 04:52 AM - edited 07-05-2021 03:53 AM
I have a stack consisting of 2 WS-C3650-24PS (version 03.03 .05SE) configured as MC and 4 AIR-CAP3702I-E-K9.
Everything is working properly and the APs are joined without problems, but only if the port of the 3650 is configured in access mode. This is a problem because i need to set up multiple SSIDs in different VLANs and i need that the AP can join in a trunk port mode.
This scenario what i have set up in other occasions WLC in 2504 and 5508 without any problem.
How do I configure multiple SSIDs in different VLANs but can I put the port mode in trunk?
Best regards.
09-08-2015 05:30 PM
This is a prerequisite for Converged access wireless where you have to connect AP directly onto switch (MA) where port is configured as a "Access Port".
You cannot connect AP on trunk port (as it is unsupported). But this will not limited to configure multiple SSID on different vlans in Converged access. Since CAPWAP establish between AP and 3650 switch, you do not want dot1q trunk between AP and Switch.
Rasika
*** Pls rate all useful responses ***
09-09-2015 12:01 AM
Hi Rasika,
If the port is configured in access mode, how the aps put the traffic in the correct vlan?
There are any configuration special in the port or in the wlan?
Best regards.
09-09-2015 05:14 AM
Hi ,
WLC and AP establish CAPWAP tunnel and all traffic flow in it.
here is the link which tells u more about LWAPP/CAPWAP traffic study..
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_white_paper09186a0080901caa.shtml
Don't forget to rate helpful posts
09-14-2015 03:33 AM
Hi Rasika,
And the AP has to be necessarily connected to a 3650 MC mode in 3650 in MA or another way, is it right?
There is an official document discuss this restriction?
Best regards.
09-27-2015 04:18 AM
can albertofdez guide me to configure the AIR-CAP3702I-E-K9 , plz when I login I can't get global config mode. plz help me
09-27-2015 05:25 AM
Use this command : debug capwap console cli
dont forget to rate helpful post
09-27-2015 05:41 AM
You will be using a lightweight version and therefore can not enter setup mode. Use these commands
ap#debug capwap console cli
ap#configure terminal
09-27-2015 11:37 PM
I am not able to go console cli
ap# debug capwap ?
client
mcast
mfp
these only I can see
09-28-2015 12:48 AM
Just give this command altogether:
regrads
