3702e not registering
javier0011
Frequent Visitor
Frequent Visitor
We have 5 3702e AP connected to a 3850. Four of the APs have registered properly, the fifth one will not stop attempting to download the IOS version from the WLC. Even when I shut the port on which the AP is connected and (sh ap sum) the fifth AP appears and prompts DOWNLOADING
AP Name                           AP Model  Ethernet MAC    Radio MAC       State
AP88f0.31f4.120c                  3702E     88f0.31f4.120c  88f0.31f4.1200  Downloading
These are the only logs that the 3850 reports when the AP is on
*%CAPWAP-3-INVALID_STATE_EVENT: 1 wcm:  Invalid AP event (CAPWAP Discovery Request) and state (CAPWAP Join Response) combination[...It occurred 2 times/sec!.]
%IOSXE-7-PLATFORM: 1 process wcm:  System has been upgrading Radio SW for more than 30 minutes.
%OSAPI-0-RAD_SW_UPGRADE: 1 wcm:  System has been upgrading Radio SW for more than 30 minutes.
I reset the AP by holding the mode button and the error still persists.
9 Replies 9
Rasika Nayanajith
Pls attach the AP console output while it is booting & trying to register to your 3850 WLC
Rasika
IOS Bootloader - Starting system.
flash is writable
Tide XL MB - 40MB of flash
Xmodem file system is available.
flashfs[0]: 11 files, 2 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 41158656
flashfs[0]: Bytes used: 7351296
flashfs[0]: Bytes available: 33807360
flashfs[0]: flashfs fsck took 10 seconds.
Base Ethernet MAC address: 88:f0:31:f4:12:0c
Ethernet speed is 1000 Mb - FULL Duplex
Loading "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-mx"...##########################
File "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-mx" uncompressed and installed, entry point: 0x2003000
executing...
Secondary Bootloader - Starting system.
Boot CMD: 'boot  flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx'
Loading "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx"...######################
File "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx" uncompressed and installed, entry point: 0x1003000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C3700 Software (AP3G2-RCVK9W8-M), Version 15.2(4)JB1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Sat 16-Nov-13 10:46 by prod_rel_team
Initializing flashfs...
flashfs[2]: 11 files, 2 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 40900608
flashfs[2]: Bytes used: 7351296
flashfs[2]: Bytes available: 33549312
flashfs[2]: flashfs fsck took 10 seconds.
flashfs[2]: Initialization complete.
flashfs[3]: 0 files, 1 directories
flashfs[3]: 0 orphaned files, 0 orphaned directories
flashfs[3]: Total bytes: 11999232
flashfs[3]: Bytes used: 1024
flashfs[3]: Bytes available: 11998208
flashfs[3]: flashfs fsck took 0 seconds.
flashfs[3]: Initialization complete.
Copying radio files from flash: to ram:
%Error opening flash:/ap3g2-rcvk9w8-mx/E2.bin (No such file or directory)
%Error opening flash:/ap3g2-rcvk9w8-mx/B2.bin (No such file or directory)
%Error opening flash:/ap3g2-rcvk9w8-mx/V2.bin (No such file or directory)
%Error opening flash:/ap3g2-rcvk9w8-mx/X2.bin (No such file or directory)
%Error opening flash:/ap3g2-rcvk9w8-mx/Y2.bin (No such file or directory)
%Error opening flash:/ap3g2-rcvk9w8-mx/R2.bin (No such file or directory)
%Error opening flash:/ap3g2-rcvk9w8-mx/Q2.bin (No such file or directory)
%Error opening flash:/ap3g2-rcvk9w8-mx/C2.bin (No such file or directory)
Uncompressing radio files...
File not found: flash:/ap3g2-rcvk9w8-mx/8004.img
File not found: flash:/ap3g2-rcvk9w8-mx/E5.bin
File not found: flash:/ap3g2-rcvk9w8-mx/B5.bin
File not found: flash:/ap3g2-rcvk9w8-mx/V5.bin
File not found: flash:/ap3g2-rcvk9w8-mx/X5.bin
File not found: flash:/ap3g2-rcvk9w8-mx/Y5.bin
File not found: flash:/ap3g2-rcvk9w8-mx/R5.bin
File not found: flash:/ap3g2-rcvk9w8-mx/Q5.bin
File not found: flash:/ap3g2-rcvk9w8-mx/C5.bin
File not found: flash:/ap3g2-rcvk9w8-mx/8006.img
...done Initializing flashfs.
no ip http server
% Invalid input detected at '^' marker.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco AIR-CAP3702E-A-K9 (PowerPC) processor (revision A0) with 204790K/57344K bytes of memory.
Processor board ID
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 7.6.1.118
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 88:F0:31:F4:12:0C
Part Number                          : 73-15397-01
PCA Assembly Number                  : 000-00000-00
PCA Revision Number                  :
PCB Serial Number                    : FOC181650TM
Top Assembly Part Number             : 068-05055-01
Top Assembly Serial Number           :
Top Revision Number                  : A0
Product/Model Number                 : AIR-CAP3702E-A-K9
% Please define a domain-name first.
Press RETURN to get started!
APAVC: Initial WLAN Buffers Given to System is  2500
APAVC:  WlanPAKs 18174 RadioPaks  17566
set_radio_pwr_mode: bad radio unit# 0
set_radio_pwr_mode: bad radio unit# 1
*Mar  1 00:00:13.551: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
*Mar  1 00:00:15.619: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:15.979: %SYS-5-RESTART: System restarted --
*Mar  1 00:00:16.103: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
*Mar  1 00:00:16.103: %CAPWAP-3-ERRORLOG: Failed to load configuration from flash. Resetting to default configlwapp_crypto_init: MIC Present and Parsed Successfully
*Mar  1 00:00:16.227: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar  1 00:00:17.071: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to upERROR: Failed to configure ethernet promiscuous mode. Interface Descriptor mismatch
*Mar  1 00:00:20.907: DPAA Initialization Complete
*Mar  1 00:00:20.907: %SYS-3-HARIKARI: Process DPAA INIT top-level routine exited
*Mar  1 00:00:21.907: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
no bridge-group 1 source-learning
%Default route without gateway, if not a point-to-point interface, may impact performance
*Mar  1 00:00:34.771: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
*Mar  1 00:00:48.211: %CDP_PD-4-POWER_OK: 15.4 W power - NEGOTIATED inline powersource
*Mar  1 00:00:49.779: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.29.100.11, mask 255.255.255.0, hostname AP88f0.31f4.120c
Translating "CISCO-CAPWAP-CONTROLLER.pcti.tec.nj.us"...domain server (172.16.241.51)
*Mar  1 00:00:59.727: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:00:59.731: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER.pcti.tec.nj.usset_radio_pwr_mode: bad radio unit# 0
*Mar  1 00:01:48.211: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
Not in Bound state.
*Mar  1 00:01:55.231: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
*Mar  1 00:02:00.195: %CAPWAP-3-ERRORLOG: Invalid event 40 & state 2 combination.
*Mar  1 00:02:00.223: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.29.100.11, mask 255.255.255.0, hostname AP88f0
can you try resetting the AP and installing a new recovery image from cisco.com?
then just download it on your AP using tftp
AP# archive download /force-reload /over tftp://
I also faced the same issue. Identified that all the access point which is not registering into WLC is connected to same switch(3850). I physically changed the connectivity to another switch. After that it is automatically registering into WLC. So I suspect some bug in the switch ios. I upgrade switch ios from 16.4.4a to 16.06.8. after that i connected AP back to the first switch. After that its is working smoothly.
Viten Patel
what code?
can you share show tech wireless? what port is this AP connected to?
Working APs are on
software version  10.1.130
boot version         15.2.4
ios version        15.24(4)jb5h$
AP with error
software ver 7.6.1.118
boot ver 15.2.4
ios version  N/A
The APs are on gi1/0/1-5 all configured the same
mohanak
Error Message    %OSAPI-0-RAD_SW_UPGRADE: System has been upgrading Radio SW for more
than 30 minutes.
Explanation    The APs have been downloading software for the last 30 minutes. Either the network is congested or there is a mismatch between the AP image and the controller image.
Recommended Action    Copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/cisco/web/support/index.html. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://tools.cisco.com/Support/BugToolKit/. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://tools.cisco.com/ServiceRequestTool/create/launch.do, or contact your Cisco technical support representative and provide the representative with the information you have gathered.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-0MR1/message/guide/SysMsgGuide_7-0MR1/nim_null_osapi_7-0MR1_msgs17.html
Abhishek Abhishek
You need to open a case with the Technical Assistance Center via the Internet at http://tools.cisco.com/ServiceRequestTool/create/launch.do
javier0011
Frequent Visitor
Frequent Visitor
After reviewing with my coworkers. We rebooted the switch and the AP downloaded the ios version and registered on its own
