3850 as Wireless LAN Contoller
r.lundrigan
Is it possible to have a 3850 running as an MC act as a WLC for an entire campus? I have multiple 3850 stacks throughout our campus with 3700 APs connected to them. Each stack runs as a Mobility Controller. I would like to centralize the wireless management if possible by having one MC be the WLC and have the other 3850s act as mobility agents.
Rasika Nayanajith
if you use 3850 MC/MA, it is a distributed deployment. All CAPWAP tunnels from APs terminate on local MA switches.
Refer this presentation for an quick update on this technology & how you should design.
Advanced Enterprise Campus Design - Converged Access (2016 Las Vegas)
There are limitations on scalability and it is not recommend to have a 3850 stack be MC for a entire campus. You need to have MC per few buildings or per building(if it is large building with large device count)
I have deployed it in my campus, only limited to 3 nearby buildings (60 AP, 8x3850MA stacks, and 5760 as MC)
Rasika
**** Pls rate all useful responses ***
Thanks for the reply. I was leaning towards a similar setup as yours with having a 5760 act as the MC and just convert all of the 3850s to MAs. Seems to make the most sense.
Rasika,
If I went with a WLC like a 5760 or a 5520, can the WLC hang off of one of my core switches? Or does the WLC have to terminate into all of the 3850s? I was thinking I could just convert the 3850s into MAs and the MAs would detect the WLC on the network. Let me know if this is a viable option.
I would suggest if you go with a 5520 and use it as centralized controllers. No converged access. This is the most simple & solid design that you can have as of today.
If you want to go ahead with converged access design, then do not buy a 5760 or 5520 as MC. The current recommended design  guide is use a 3850 stack as MC for a given building (or multiple buildings)
Note that 100 AP limits per MC when scaling. The given presentation talks about all these limitations
Rasika
