3850 web interface slow to load, especially for webauth
Nick Shelley
Hi all,
Got a cat 3850 switch acting also as a wireless controller. Running 3.6.0E One thing that I've noticed is that loading the web interface to configure it is terribly slow.  Also for guest authentication, it takes a long time for the web page to load.  Tried IE and firefox with same results.
Thoughts?
Rasika Nayanajith
GUI of these platforms(3850/5760/3650) are not that reliable.
This is IOS, do it via CLI (that's what I would do), I know it is bit hard, but once you learn it, GUI is not that important
Rasika
Hey thanks for the reply Rasika.  Yes, I'm aware that the GUI isn't quite there yet.  However for the webauth, I would expect it to be somewhat fast.  The webauth file is custom, but small.
Here's the contents of the flash directory and some config:
3850#sh start | inc webauth
aaa authentication login webauth_local local
service-template webauth-global-inactive
parameter-map type webauth global
parameter-map type webauth guest_web
 type webauth
 custom-page login device flash:/webauth/webauth_login.html
 custom-page success device flash:/webauth/webauth_success.html
 custom-page failure device flash:/webauth/webauth_failure.html
 custom-page login expired device flash:/webauth/webauth_expired.html
 security web-auth authentication-list webauth_local
3850#sh flash:
-#- --length-- ---------date/time--------- path
  2    2097152 Oct 24 2014 20:58:23.0000000000 +00:00 nvram_config
  3     742912 Oct 20 2014 19:16:56.0000000000 +00:00 webauth.tar
  4       4096 Oct 20 2014 19:16:58.0000000000 +00:00 webauth
  5       4096 Oct 20 2014 19:16:57.0000000000 +00:00 webauth/css
  6       2098 Oct 20 2014 19:16:57.0000000000 +00:00 webauth/css/signin.css
  7         96 Oct 20 2014 19:16:57.0000000000 +00:00 webauth/css/starter-template.css
  8       4096 Oct 20 2014 19:16:57.0000000000 +00:00 webauth/dist
  9       4096 Oct 20 2014 19:16:57.0000000000 +00:00 webauth/dist/css
 10      19791 Oct 20 2014 19:16:57.0000000000 +00:00 webauth/dist/css/bootstrap-theme.css
 11      17706 Oct 20 2014 19:16:57.0000000000 +00:00 webauth/dist/css/bootstrap-theme.min.css
 12     126432 Oct 20 2014 19:16:57.0000000000 +00:00 webauth/dist/css/bootstrap.css
 13     102897 Oct 20 2014 19:16:57.0000000000 +00:00 webauth/dist/css/bootstrap.min.css
 14       4096 Oct 20 2014 19:16:57.0000000000 +00:00 webauth/dist/fonts
 15      20290 Oct 20 2014 19:16:57.0000000000 +00:00 webauth/dist/fonts/glyphicons-halflings-regular.eot
 16      62850 Oct 20 2014 19:16:57.0000000000 +00:00 webauth/dist/fonts/glyphicons-halflings-regular.svg
 17      41236 Oct 20 2014 19:16:57.0000000000 +00:00 webauth/dist/fonts/glyphicons-halflings-regular.ttf
 18      23292 Oct 20 2014 19:16:57.0000000000 +00:00 webauth/dist/fonts/glyphicons-halflings-regular.woff
 19       4096 Oct 20 2014 19:16:57.0000000000 +00:00 webauth/dist/js
 20      58327 Oct 20 2014 19:16:57.0000000000 +00:00 webauth/dist/js/bootstrap.js
 21      27748 Oct 20 2014 19:16:57.0000000000 +00:00 webauth/dist/js/bootstrap.min.js
 22       4096 Oct 20 2014 19:16:58.0000000000 +00:00 webauth/img
 23      98601 Oct 20 2014 19:16:58.0000000000 +00:00 webauth/img/web_auth_background_blur.jpg
 24        174 Oct 20 2014 19:16:58.0000000000 +00:00 webauth/img/web_auth_close.png
 25      30325 Oct 20 2014 19:16:58.0000000000 +00:00 webauth/img/web_auth_onloklogo.jpg
 26       5768 Oct 20 2014 19:16:58.0000000000 +00:00 webauth/img/web_auth_onlok_logo.png
 27        251 Oct 20 2014 19:16:58.0000000000 +00:00 webauth/img/web_auth_open.png
 28       4096 Oct 20 2014 19:16:58.0000000000 +00:00 webauth/js
 29       3861 Oct 20 2014 19:16:58.0000000000 +00:00 webauth/js/affix.js
 30       2582 Oct 20 2014 19:16:58.0000000000 +00:00 webauth/js/alert.js
 31       3048 Oct 20 2014 19:16:58.0000000000 +00:00 webauth/js/button.js
 32       6445 Oct 20 2014 19:16:58.0000000000 +00:00 webauth/js/carousel.js
 33       5228 Oct 20 2014 19:16:58.0000000000 +00:00 webauth/js/collapse.js
 34       4484 Oct 20 2014 19:16:58.0000000000 +00:00 webauth/js/dropdown.js
 35       2636 Oct 20 2014 19:16:58.0000000000 +00:00 webauth/js/html5shiv.min.js
 36        694 Oct 20 2014 19:16:58.0000000000 +00:00 webauth/js/ie10-viewport-bug-workaround.js
 37       6975 Oct 20 2014 19:16:58.0000000000 +00:00 webauth/js/modal.js
 38       3488 Oct 20 2014 19:16:58.0000000000 +00:00 webauth/js/popover.js
 39       4377 Oct 20 2014 19:16:58.0000000000 +00:00 webauth/js/respond.min.js
 40       4622 Oct 20 2014 19:16:58.0000000000 +00:00 webauth/js/scrollspy.js
 41       3413 Oct 20 2014 19:16:58.0000000000 +00:00 webauth/js/tab.js
 42      11908 Oct 20 2014 19:16:58.0000000000 +00:00 webauth/js/tooltip.js
 43       1964 Oct 20 2014 19:16:58.0000000000 +00:00 webauth/js/transition.js
 44       1334 Oct 20 2014 19:16:58.0000000000 +00:00 webauth/webauth_expired.html
 45       1618 Oct 20 2014 19:16:58.0000000000 +00:00 webauth/webauth_failure.html
 46       1932 Oct 20 2014 19:16:58.0000000000 +00:00 webauth/webauth_login.html
 47       1641 Oct 20 2014 19:16:58.0000000000 +00:00 webauth/webauth_success.html
 48      10445 Oct 28 2014 19:03:11.0000000000 +00:00 wnweb.tgz
 49   82672260 Oct 19 2014 06:29:54.0000000000 +00:00 cat3k_caa-base.SPA.03.06.00E.pkg
 50    6601404 Oct 19 2014 06:29:54.0000000000 +00:00 cat3k_caa-drivers.SPA.03.06.00E.pkg
 51       1235 Oct 19 2014 06:29:59.0000000000 +00:00 packages.conf
 52       1156 Oct 19 2014 06:43:36.0000000000 +00:00 vlan.dat
 53   33747948 Oct 19 2014 06:29:54.0000000000 +00:00 cat3k_caa-infra.SPA.03.06.00E.pkg
 54       4096 Dec 27 2013 03:17:04.0000000000 +00:00 mnt
 55       4096 Dec 27 2013 03:17:04.0000000000 +00:00 mnt/images
 56       4096 Dec 27 2013 03:17:09.0000000000 +00:00 mnt/images/ap.bak
 57         40 Dec 05 2013 18:36:37.0000000000 +00:00 mnt/images/ap.bak/ap1g2.md5
 58   11612160 Dec 05 2013 18:36:37.0000000000 +00:00 mnt/images/ap.bak/ap1g2
 59         40 Dec 05 2013 18:36:37.0000000000 +00:00 mnt/images/ap.bak/ap3g1.md5
 60   10475520 Dec 05 2013 18:36:38.0000000000 +00:00 mnt/images/ap.bak/ap3g1
 61         40 Dec 05 2013 18:36:37.0000000000 +00:00 mnt/images/ap.bak/ap3g2.md5
 62   13670400 Dec 05 2013 18:36:37.0000000000 +00:00 mnt/images/ap.bak/ap3g2
 63         40 Dec 05 2013 18:36:37.0000000000 +00:00 mnt/images/ap.bak/c1140.md5
 64   10321920 Dec 05 2013 18:36:37.0000000000 +00:00 mnt/images/ap.bak/c1140
 65         11 Dec 05 2013 18:36:37.0000000000 +00:00 mnt/images/ap.bak/version.info
 66   42769724 Oct 19 2014 06:29:54.0000000000 +00:00 cat3k_caa-iosd-universalk9.SPA.152-2.E.pkg
 67       4096 Oct 19 2014 06:42:45.0000000000 +00:00 dc_profile_dir
 68     169223 Oct 19 2014 06:42:45.0000000000 +00:00 dc_profile_dir/dc_default_profiles.txt
 69     169223 Oct 19 2014 06:42:45.0000000000 +00:00 dc_profile_dir/dc_default_profiles.txt.bkp
 70   25711500 Oct 19 2014 06:29:54.0000000000 +00:00 cat3k_caa-platform.SPA.03.06.00E.pkg
 71   98462528 Oct 19 2014 06:29:55.0000000000 +00:00 cat3k_caa-wcm.SPA.10.2.102.0.pkg
1196404736 bytes available (343171072 bytes used)
