3D Model Request for IW9167E
angier
Visitor
Is there a 3D model available for IW9167E?
Prince.O
The attached file shows the antenna patterns for visualization. If you will like to see a 3D/more detailed visualization for deployment , i will recommend using a survey tool such as Ekahau or Hamina to visualize the coverage for your design needs
