3G cellular interface not working
mohdtaamneh
Frequent Visitor
Frequent Visitor
Dears,
I need your help in find the root cause for the following behavior.
I am trying to configure a cellular interface on  cisco C881G-4G-GA-K9 router as 3G. But the interface not operational. its showing up/up (spoofing) and not getting IP address from SP as suppose to do.
Router#sho int cellular 0
Cellular0 is up (spoofing), line protocol is up (spoofing)
Hardware is 4G WWAN Modem - Global (Europe & Australia) Multimode LTE/DC-HSPA+/HSPA+/HSPA/U
Internet address will be assigned dynamically by the network
MTU 1500 bytes, BW 9 Kbit/sec, DLY 100000 usec,
Encapsulation SLIP, loopback not set
Keepalive not supported
Configuration on the port as follow:
interface Cellular0
ip address negotiated
ip nat outside
ip virtual-reassembly in
encapsulation slip
dialer in-band
dialer idle-timeout 0
dialer string gsm
dialer string GSM
dialer-group 1
async mode interactive
controller Cellular 0
lte modem link-recovery rssi onset-threshold -110
lte modem link-recovery monitor-timer 20
lte modem link-recovery wait-timer 10
lte modem link-recovery debounce-count 6
I tried the same 3G sim card on cisco C881G+7-k9 router and its work fine and link come up. Also, the cellular interface getting IP address and I can reach outside.
Any special configuration need to be added on the controller/ cellular interface?
Attached is a debug output collected from the router.
Best Regards,
Mohammad Taamneh
5 Replies 5
Philip D'Ath
Meraki Community All-Star
You haven't shown enough config.  Basically you need to ...
Configre an APN.
cellular 0 lte profile create 1 <apn>
Use a dialer string like this.  You currently have two defined on your Cellular0 interface.  Get rid of one, and make sure what you add below exactly matches.
chat-script GSM "" "AT!CALL" TIMEOUT 20 "OK"
You also need a dialer-list.
dialer-list 1 protocol ip permit
And a route via the cellular interface.  If you still can't get it working please post you whole config.
attached is the complete config
Philip D'Ath
Did the modifications work that I supplied?
Will try and let you know my feedback. but I have a question regarding the config for the controller. I can't find gsm option as my old 3G router. Is the current config under the controller should work fine with 3G sim card?
Philip D'Ath
3G and 4G routers do not have the same cellular configuration.  Similar, but not the same.
The "Controller" config should be fine.
