Monitor NMSP Connection Status
Hi All,
is there chance to Monitor the NMSP Connection Status between WLC and MSE? The Customer asks for a SNMP Poll / GET on WLC or MSE to see if the NMSP works correctly. In PI we only see that it works or not, but there is no Warning or Event. REST API is also a possibility, has anybody seen something like that?
BR and TiA, Michael
Sandeep Choudhary
may be you check the active .inactive connection status on WLC by this command:
 sh nmsp status
MOre info: http://mrncciew.com/2014/09/25/what-is-nmsp/
Dont forget to rate helpful posts
Hi Sandeep, thank you for responding, i know this command, but my customer wants to do that in a little more automated way. Does SNMP Trap if NMSP fails, or is there a GET, which i can take every 10 minutes? Syslog? REST API via PI? Any Idea?
BR, MIchael
