07-08-2017 12:35 AM - edited 07-05-2021 07:18 AM
I have filtered with the mac address to make it easier. the machine with mac address 00:03:52:0e:54:a0 is facing frequest disconnection while roaming. please advise.
I also see that it is repeatedly taking 2 addresses 172.28.13.14 & 172.28.13.104 ..not sure why
Line 1107: (gzmwlc1) >Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Association received from mobile on AP 00:1c:57:8b:76:90
Line 1108: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 STA - rates (8): 130 132 139 12 18 150 24 36 48 72 96 108 0 0 0 0
Line 1109: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 STA - rates (12): 130 132 139 12 18 150 24 36 48 72 96 108 0 0 0 0
Line 1110: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Processing WPA IE type 221, length 22 for mobile 00:03:52:0e:54:a0
Line 1111: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 172.28.13.14 RUN (20) Deleted mobile LWAPP rule on AP [00:1b:0d:d5:5b:f0]
Line 1112: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Updated location for station old AP 00:00:00:00:00:00-0, new AP 00:1c:57:8b:76:90-0
Line 1113: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 172.28.13.14 RUN (20) Change state to START (0) last state RUN (20)
Line 1114: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 172.28.13.14 START (0) Initializing policy
Line 1115: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 172.28.13.14 START (0) Change state to AUTHCHECK (2) last state RUN (20)
Line 1116: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 172.28.13.14 AUTHCHECK (2) Change state to 8021X_REQD (3) last state RUN (20)
Line 1117: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 172.28.13.14 8021X_REQD (3) Plumbed mobile LWAPP rule on AP 00:1c:57:8b:76:90
Line 1118: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 apfPemAddUser2 (apf_policy.c:212) Changing state for mobile 00:03:52:0e:54:a0 on AP 00:1c:57:8b:76:90 from Associated to Associated
Line 1119: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Stopping deletion of Mobile Station: (callerId: 48)
Line 1120: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Sending Assoc Response to station on BSSID 00:1c:57:8b:76:90 (status 0)
Line 1121: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 apfProcessAssocReq (apf_80211.c:3885) Changing state for mobile 00:03:52:0e:54:a0 on AP 00:1c:57:8b:76:90 from Associated to Associated
Line 1122: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 172.28.13.14 Removed NPU entry.
Line 1123: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 dot1x - moving mobile 00:03:52:0e:54:a0 into Connecting state
Line 1124: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Sending EAP-Request/Identity to mobile 00:03:52:0e:54:a0 (EAP Id 1)
Line 1125: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Received EAPOL EAPPKT from mobile 00:03:52:0e:54:a0
Line 1126: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Received Identity Response (count=1) from mobile 00:03:52:0e:54:a0
Line 1127: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 EAP State update from Connecting to Authenticating for mobile 00:03:52:0e:54:a0
Line 1128: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 dot1x - moving mobile 00:03:52:0e:54:a0 into Authenticating state
Line 1129: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Entering Backend Auth Response state for mobile 00:03:52:0e:54:a0
Line 1130: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Processing Access-Challenge for mobile 00:03:52:0e:54:a0
Line 1131: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Entering Backend Auth Req state (id=2) for mobile 00:03:52:0e:54:a0
Line 1132: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Sending EAP Request from AAA to mobile 00:03:52:0e:54:a0 (EAP Id 2)
Line 1133: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Received EAPOL EAPPKT from mobile 00:03:52:0e:54:a0
Line 1134: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Received EAP Response from mobile 00:03:52:0e:54:a0 (EAP Id 2, EAP Type 25)
Line 1135: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Entering Backend Auth Response state for mobile 00:03:52:0e:54:a0
Line 1136: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Processing Access-Challenge for mobile 00:03:52:0e:54:a0
Line 1137: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Entering Backend Auth Req state (id=3) for mobile 00:03:52:0e:54:a0
Line 1138: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Sending EAP Request from AAA to mobile 00:03:52:0e:54:a0 (EAP Id 3)
Line 1139: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Received EAPOL EAPPKT from mobile 00:03:52:0e:54:a0
Line 1140: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Received EAP Response from mobile 00:03:52:0e:54:a0 (EAP Id 3, EAP Type 25)
Line 1141: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Entering Backend Auth Response state for mobile 00:03:52:0e:54:a0
Line 1142: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Processing Access-Challenge for mobile 00:03:52:0e:54:a0
Line 1143: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Entering Backend Auth Req state (id=6) for mobile 00:03:52:0e:54:a0
Line 1144: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 WARNING: updated EAP-Identifer 3 ===> 6 for STA 00:03:52:0e:54:a0
Line 1145: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Sending EAP Request from AAA to mobile 00:03:52:0e:54:a0 (EAP Id 6)
Line 1146: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Received EAPOL EAPPKT from mobile 00:03:52:0e:54:a0
Line 1147: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Received EAP Response from mobile 00:03:52:0e:54:a0 (EAP Id 6, EAP Type 25)
Line 1148: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Entering Backend Auth Response state for mobile 00:03:52:0e:54:a0
Line 1149: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Processing Access-Accept for mobile 00:03:52:0e:54:a0
Line 1150: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Setting re-auth timeout to 1800 seconds, got from WLAN config.
Line 1151: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Station 00:03:52:0e:54:a0 setting dot1x reauth timeout = 1800
Line 1152: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Creating a PKC PMKID Cache entry for station 00:03:52:0e:54:a0 (RSN 0)
Line 1153: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Sending EAP-Success to mobile 00:03:52:0e:54:a0 (EAP Id 6)
Line 1154: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Sending EAPOL-Key Message to mobile 00:03:52:0e:54:a0
Line 1156: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Entering Backend Auth Success state (id=6) for mobile 00:03:52:0e:54:a0
Line 1157: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Received Auth Success while in Authenticating state for mobile 00:03:52:0e:54:a0
Line 1158: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 dot1x - moving mobile 00:03:52:0e:54:a0 into Authenticated state
Line 1159: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Received EAPOL-Key from mobile 00:03:52:0e:54:a0
Line 1160: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Received EAPOL-key in PKT_START state (message 2) from mobile 00:03:52:0e:54:a0
Line 1161: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Stopping retransmission timer for mobile 00:03:52:0e:54:a0
Line 1162: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Sending EAPOL-Key Message to mobile 00:03:52:0e:54:a0
Line 1164: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Received EAPOL-Key from mobile 00:03:52:0e:54:a0
Line 1165: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Received EAPOL-key in PTKINITNEGOTIATING state (message 4) from mobile 00:03:52:0e:54:a0
Line 1166: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 172.28.13.14 8021X_REQD (3) Change state to L2AUTHCOMPLETE (4) last state RUN (20)
Line 1167: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 172.28.13.14 L2AUTHCOMPLETE (4) Plumbed mobile LWAPP rule on AP 00:1c:57:8b:76:90
Line 1168: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 172.28.13.14 L2AUTHCOMPLETE (4) Change state to RUN (20) last state RUN (20)
Line 1169: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 172.28.13.14 RUN (20) Reached PLUMBFASTPATH: from line 4354
Line 1170: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 172.28.13.14 RUN (20) Adding Fast Path rule
Line 1174: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 172.28.13.14 RUN (20) Successfully plumbed mobile rule (ACL ID 255)
Line 1175: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Stopping retransmission timer for mobile 00:03:52:0e:54:a0
Line 1176: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Sending EAPOL-Key Message to mobile 00:03:52:0e:54:a0
Line 1178: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Sent EAPOL-Key M5 for mobile 00:03:52:0e:54:a0
Line 1179: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 172.28.13.14 Added NPU entry of type 1
Line 1180: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Received EAPOL-Key from mobile 00:03:52:0e:54:a0
Line 1181: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Received EAPOL-key in REKEYNEGOTIATING state (message 6) from mobile 00:03:52:0e:54:a0
Line 1182: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 Stopping retransmission timer for mobile 00:03:52:0e:54:a0
Line 1183: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 DHCP received op BOOTREQUEST (1) (len 308, port 29, encap 0xec03)
Line 1184: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 DHCP processing DHCP REQUEST (3)
Line 1185: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 DHCP op: BOOTREQUEST, htype: Ethernet, hlen: 6, hops: 0
Line 1186: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 DHCP xid: 0xc62031d (207749917), secs: 0, flags: 0
Line 1187: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 DHCP chaddr: 00:03:52:0e:54:a0
Line 1188: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 DHCP ciaddr: 0.0.0.0, yiaddr: 0.0.0.0
Line 1189: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 DHCP siaddr: 0.0.0.0, giaddr: 0.0.0.0
Line 1190: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 DHCP requested ip: 172.28.13.14
Line 1191: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 DHCP successfully bridged packet to DS
Line 1192: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 DHCP received op BOOTREPLY (2) (len 321, port 29, encap 0xec00)
Line 1193: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 DHCP processing DHCP ACK (5)
Line 1194: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 DHCP op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
Line 1195: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 DHCP xid: 0xc62031d (207749917), secs: 0, flags: 0
Line 1196: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 DHCP chaddr: 00:03:52:0e:54:a0
Line 1197: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 DHCP ciaddr: 0.0.0.0, yiaddr: 172.28.13.14
Line 1198: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 DHCP siaddr: 0.0.0.0, giaddr: 172.28.13.1
Line 1199: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 DHCP server id: 172.28.25.6 rcvd server id: 172.28.25.6
Line 1200: Thu May 18 05:00:29 2017: 00:03:52:0e:54:a0 DHCP successfully bridged packet to STA
Line 1201: Thu May 18 05:04:06 2017: 00:03:52:0e:54:a0 Sending EAPOL-Key Message to mobile 00:03:52:0e:54:a0
Line 1203: Thu May 18 05:04:06 2017: 00:03:52:0e:54:a0 Updated broadcast key sent to mobile 00:03:52:0E:54:A0
Line 1204: Thu May 18 05:04:06 2017: 00:03:52:0e:54:a0 Received EAPOL-Key from mobile 00:03:52:0e:54:a0
Line 1205: Thu May 18 05:04:06 2017: 00:03:52:0e:54:a0 Received EAPOL-key in REKEYNEGOTIATING state (message 6) from mobile 00:03:52:0e:54:a0
Line 1206: Thu May 18 05:04:06 2017: 00:03:52:0e:54:a0 Stopping retransmission timer for mobile 00:03:52:0e:54:a0
Line 1207: Thu May 18 05:04:48 2017: 00:03:52:0e:54:a0 172.28.13.14 RUN (20) Change state to DHCP_REQD (7) last state RUN (20)
Line 1208: Thu May 18 05:04:48 2017: 00:03:52:0e:54:a0 172.28.13.14 DHCP_REQD (7) pemAdvanceState2 3850, Adding TMP rule
Line 1209: Thu May 18 05:04:48 2017: 00:03:52:0e:54:a0 172.28.13.14 DHCP_REQD (7) Replacing Fast Path rule
Line 1213: Thu May 18 05:04:48 2017: 00:03:52:0e:54:a0 172.28.13.14 DHCP_REQD (7) Successfully plumbed mobile rule (ACL ID 255)
Line 1214: Thu May 18 05:04:48 2017: 00:03:52:0e:54:a0 172.28.13.104 DHCP_REQD (7) Change state to RUN (20) last state RUN (20)
Line 1215: Thu May 18 05:04:48 2017: 00:03:52:0e:54:a0 172.28.13.104 RUN (20) Reached PLUMBFASTPATH: from line 4717
Line 1216: Thu May 18 05:04:48 2017: 00:03:52:0e:54:a0 172.28.13.104 RUN (20) Replacing Fast Path rule
Line 1220: Thu May 18 05:04:48 2017: 00:03:52:0e:54:a0 172.28.13.104 RUN (20) Successfully plumbed mobile rule (ACL ID 255)
Line 1221: Thu May 18 05:04:48 2017: 00:03:52:0e:54:a0 Assigning Address 172.28.13.104 to mobile
Line 1222: Thu May 18 05:04:48 2017: 00:03:52:0e:54:a0 172.28.13.14 Added NPU entry of type 9
Line 1223: Thu May 18 05:04:48 2017: 00:03:52:0e:54:a0 172.28.13.104 Added NPU entry of type 1
Line 1236: MAC address ................................ 00:03:52:0e:54:a0
Line 2721: MAC address ................................ 00:03:52:0e:54:a0
Line 2767: (gzmwlc1) >debug client 00:03:52:0e:54:a0 ?
Line 2769: (gzmwlc1) >debug client 00:03:52:0e:54:a0
Line 2779: MAC address ................................ 00:03:52:0e:54:a0
Line 2793: MAC address ................................ 00:03:52:0e:54:a0
Line 3274: --More-- or (q)uitThu May 18 05:24:49 2017: 00:03:52:0e:54:a0 172.28.13.14 RUN (20) Change state to DHCP_REQD (7) last state RUN (20)
Line 3275: Thu May 18 05:24:49 2017: 00:03:52:0e:54:a0 172.28.13.14 DHCP_REQD (7) pemAdvanceState2 3850, Adding TMP rule
Line 3276: Thu May 18 05:24:49 2017: 00:03:52:0e:54:a0 172.28.13.14 DHCP_REQD (7) Replacing Fast Path rule
Line 3280: Thu May 18 05:24:49 2017: 00:03:52:0e:54:a0 172.28.13.14 DHCP_REQD (7) Successfully plumbed mobile rule (ACL ID 255)
Line 3281: Thu May 18 05:24:49 2017: 00:03:52:0e:54:a0 172.28.13.104 DHCP_REQD (7) Change state to RUN (20) last state RUN (20)
Line 3282: Thu May 18 05:24:49 2017: 00:03:52:0e:54:a0 172.28.13.104 RUN (20) Reached PLUMBFASTPATH: from line 4717
Line 3283: Thu May 18 05:24:49 2017: 00:03:52:0e:54:a0 172.28.13.104 RUN (20) Replacing Fast Path rule
Line 3287: Thu May 18 05:24:49 2017: 00:03:52:0e:54:a0 172.28.13.104 RUN (20) Successfully plumbed mobile rule (ACL ID 255)
Line 3288: Thu May 18 05:24:49 2017: 00:03:52:0e:54:a0 Assigning Address 172.28.13.104 to mobile
Line 3289: Thu May 18 05:24:49 2017: 00:03:52:0e:54:a0 172.28.13.14 Added NPU entry of type 9
Line 3290: Thu May 18 05:24:49 2017: 00:03:52:0e:54:a0 172.28.13.104 Added NPU entry of type 1
Line 3451: MAC address ................................ 00:03:52:0e:54:a0
Line 3463: (gzmwlc1) >Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Association received from mobile on AP 00:23:ea:00:2d:b0
Line 3464: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 STA - rates (8): 130 132 139 12 18 150 24 36 48 72 96 108 0 0 0 0
Line 3465: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 STA - rates (12): 130 132 139 12 18 150 24 36 48 72 96 108 0 0 0 0
Line 3466: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Processing WPA IE type 221, length 22 for mobile 00:03:52:0e:54:a0
Line 3467: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 172.28.13.104 RUN (20) Deleted mobile LWAPP rule on AP [00:1b:0d:d4:81:20]
Line 3468: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Updated location for station old AP 00:00:00:00:00:00-0, new AP 00:23:ea:00:2d:b0-0
Line 3469: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 172.28.13.104 RUN (20) Change state to START (0) last state RUN (20)
Line 3470: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 172.28.13.104 START (0) Initializing policy
Line 3471: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 172.28.13.104 START (0) Change state to AUTHCHECK (2) last state RUN (20)
Line 3472: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 172.28.13.104 AUTHCHECK (2) Change state to 8021X_REQD (3) last state RUN (20)
Line 3473: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 172.28.13.104 8021X_REQD (3) Plumbed mobile LWAPP rule on AP 00:23:ea:00:2d:b0
Line 3474: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 apfPemAddUser2 (apf_policy.c:212) Changing state for mobile 00:03:52:0e:54:a0 on AP 00:23:ea:00:2d:b0 from Associated to Associated
Line 3475: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Stopping deletion of Mobile Station: (callerId: 48)
Line 3476: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Sending Assoc Response to station on BSSID 00:23:ea:00:2d:b0 (status 0)
Line 3477: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 apfProcessAssocReq (apf_80211.c:3885) Changing state for mobile 00:03:52:0e:54:a0 on AP 00:23:ea:00:2d:b0 from Associated to Associated
Line 3478: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 172.28.13.104 Removed NPU entry.
Line 3479: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 dot1x - moving mobile 00:03:52:0e:54:a0 into Connecting state
Line 3480: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Sending EAP-Request/Identity to mobile 00:03:52:0e:54:a0 (EAP Id 1)
Line 3481: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Received EAPOL EAPPKT from mobile 00:03:52:0e:54:a0
Line 3482: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Received Identity Response (count=1) from mobile 00:03:52:0e:54:a0
Line 3483: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 EAP State update from Connecting to Authenticating for mobile 00:03:52:0e:54:a0
Line 3484: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 dot1x - moving mobile 00:03:52:0e:54:a0 into Authenticating state
Line 3485: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Entering Backend Auth Response state for mobile 00:03:52:0e:54:a0
Line 3486: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Processing Access-Challenge for mobile 00:03:52:0e:54:a0
Line 3487: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Entering Backend Auth Req state (id=2) for mobile 00:03:52:0e:54:a0
Line 3488: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Sending EAP Request from AAA to mobile 00:03:52:0e:54:a0 (EAP Id 2)
Line 3489: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Received EAPOL EAPPKT from mobile 00:03:52:0e:54:a0
Line 3490: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Received EAP Response from mobile 00:03:52:0e:54:a0 (EAP Id 2, EAP Type 25)
Line 3491: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Entering Backend Auth Response state for mobile 00:03:52:0e:54:a0
Line 3492: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Processing Access-Challenge for mobile 00:03:52:0e:54:a0
Line 3493: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Entering Backend Auth Req state (id=3) for mobile 00:03:52:0e:54:a0
Line 3494: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Sending EAP Request from AAA to mobile 00:03:52:0e:54:a0 (EAP Id 3)
Line 3495: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Received EAPOL EAPPKT from mobile 00:03:52:0e:54:a0
Line 3496: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Received EAP Response from mobile 00:03:52:0e:54:a0 (EAP Id 3, EAP Type 25)
Line 3497: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Entering Backend Auth Response state for mobile 00:03:52:0e:54:a0
Line 3498: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Processing Access-Challenge for mobile 00:03:52:0e:54:a0
Line 3499: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Entering Backend Auth Req state (id=6) for mobile 00:03:52:0e:54:a0
Line 3500: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 WARNING: updated EAP-Identifer 3 ===> 6 for STA 00:03:52:0e:54:a0
Line 3501: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Sending EAP Request from AAA to mobile 00:03:52:0e:54:a0 (EAP Id 6)
Line 3502: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Received EAPOL EAPPKT from mobile 00:03:52:0e:54:a0
Line 3503: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Received EAP Response from mobile 00:03:52:0e:54:a0 (EAP Id 6, EAP Type 25)
Line 3504: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Entering Backend Auth Response state for mobile 00:03:52:0e:54:a0
Line 3505: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Processing Access-Accept for mobile 00:03:52:0e:54:a0
Line 3506: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Setting re-auth timeout to 1800 seconds, got from WLAN config.
Line 3507: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Station 00:03:52:0e:54:a0 setting dot1x reauth timeout = 1800
Line 3508: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Creating a PKC PMKID Cache entry for station 00:03:52:0e:54:a0 (RSN 0)
Line 3509: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Sending EAP-Success to mobile 00:03:52:0e:54:a0 (EAP Id 6)
Line 3510: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Sending EAPOL-Key Message to mobile 00:03:52:0e:54:a0
Line 3512: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Entering Backend Auth Success state (id=6) for mobile 00:03:52:0e:54:a0
Line 3513: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Received Auth Success while in Authenticating state for mobile 00:03:52:0e:54:a0
Line 3514: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 dot1x - moving mobile 00:03:52:0e:54:a0 into Authenticated state
Line 3515: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Received EAPOL-Key from mobile 00:03:52:0e:54:a0
Line 3516: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Received EAPOL-key in PKT_START state (message 2) from mobile 00:03:52:0e:54:a0
Line 3517: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Stopping retransmission timer for mobile 00:03:52:0e:54:a0
Line 3518: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Sending EAPOL-Key Message to mobile 00:03:52:0e:54:a0
Line 3520: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Received EAPOL-Key from mobile 00:03:52:0e:54:a0
Line 3521: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Received EAPOL-key in PTKINITNEGOTIATING state (message 4) from mobile 00:03:52:0e:54:a0
Line 3522: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 172.28.13.104 8021X_REQD (3) Change state to L2AUTHCOMPLETE (4) last state RUN (20)
Line 3523: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 172.28.13.104 L2AUTHCOMPLETE (4) Plumbed mobile LWAPP rule on AP 00:23:ea:00:2d:b0
Line 3524: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 172.28.13.104 L2AUTHCOMPLETE (4) Change state to RUN (20) last state RUN (20)
Line 3525: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 172.28.13.104 RUN (20) Reached PLUMBFASTPATH: from line 4354
Line 3526: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 172.28.13.104 RUN (20) Adding Fast Path rule
Line 3530: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 172.28.13.104 RUN (20) Successfully plumbed mobile rule (ACL ID 255)
Line 3531: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Stopping retransmission timer for mobile 00:03:52:0e:54:a0
Line 3532: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Sending EAPOL-Key Message to mobile 00:03:52:0e:54:a0
Line 3534: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Sent EAPOL-Key M5 for mobile 00:03:52:0e:54:a0
Line 3535: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 172.28.13.104 Added NPU entry of type 1
Line 3536: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Received EAPOL-Key from mobile 00:03:52:0e:54:a0
Line 3537: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Received EAPOL-key in REKEYNEGOTIATING state (message 6) from mobile 00:03:52:0e:54:a0
Line 3538: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Stopping retransmission timer for mobile 00:03:52:0e:54:a0
Line 3539: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 DHCP received op BOOTREQUEST (1) (len 308, port 29, encap 0xec03)
Line 3540: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 DHCP processing DHCP REQUEST (3)
Line 3541: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 DHCP op: BOOTREQUEST, htype: Ethernet, hlen: 6, hops: 0
Line 3542: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 DHCP xid: 0xec710cd (247926989), secs: 0, flags: 0
Line 3543: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 DHCP chaddr: 00:03:52:0e:54:a0
Line 3544: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 DHCP ciaddr: 0.0.0.0, yiaddr: 0.0.0.0
Line 3545: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 DHCP siaddr: 0.0.0.0, giaddr: 0.0.0.0
Line 3546: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 DHCP requested ip: 172.28.13.14
Line 3547: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 DHCP successfully bridged packet to DS
Line 3548: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 DHCP received op BOOTREPLY (2) (len 321, port 29, encap 0xec00)
Line 3549: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 DHCP processing DHCP ACK (5)
Line 3550: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 DHCP op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
Line 3551: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 DHCP xid: 0xec710cd (247926989), secs: 0, flags: 0
Line 3552: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 DHCP chaddr: 00:03:52:0e:54:a0
Line 3553: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 DHCP ciaddr: 0.0.0.0, yiaddr: 172.28.13.14
Line 3554: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 DHCP siaddr: 0.0.0.0, giaddr: 172.28.13.1
Line 3555: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 DHCP server id: 172.28.25.6 rcvd server id: 172.28.25.6
Line 3556: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 172.28.13.104 RUN (20) Change state to DHCP_REQD (7) last state RUN (20)
Line 3557: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 172.28.13.104 DHCP_REQD (7) pemAdvanceState2 3850, Adding TMP rule
Line 3558: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 172.28.13.104 DHCP_REQD (7) Replacing Fast Path rule
Line 3562: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 172.28.13.104 DHCP_REQD (7) Successfully plumbed mobile rule (ACL ID 255)
Line 3563: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 172.28.13.14 DHCP_REQD (7) Change state to RUN (20) last state RUN (20)
Line 3564: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 172.28.13.14 RUN (20) Reached PLUMBFASTPATH: from line 4717
Line 3565: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 172.28.13.14 RUN (20) Replacing Fast Path rule
Line 3569: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 172.28.13.14 RUN (20) Successfully plumbed mobile rule (ACL ID 255)
Line 3570: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 Assigning Address 172.28.13.14 to mobile
Line 3571: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 DHCP successfully bridged packet to STA
Line 3572: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 172.28.13.104 Added NPU entry of type 9
Line 3573: Thu May 18 05:25:55 2017: 00:03:52:0e:54:a0 172.28.13.14 Added NPU entry of type 1
Line 4018: MAC address ................................ 00:03:52:0e:54:a0
Line 4045: MAC address ................................ 00:03:52:0e:54:a0
