4402 controller = Limit certain ssid/Wlan to certain APs, possible?
krille_com
we have one 4402 wireless controller thats run about 15 Lightweight APs.
Is it possible to descide which APs that should have which Wlans? if it is, then how?
Grateful for any help!
Kristoffer
ankbhasi
Hi Kris,
Yes it is very well possible using WLAN Override feature.
This link will clearly guide you how to achieve the same
http://www.cisco.com/en/US/docs/wireless/controller/4.2/configuration/guide/c42wlan.html#wp1127323
Incase you have any doubts please come back with the same.
Ankur
*Pls rate all helpful post
ankbhasi
Hi Kris,
Ankur
Thank you, that document said it all!
