on the controller, under security, AAA, RADIUS Authentication. Add an entry for your ACS server. then under the WLAN, that you want to associate to the ACS, pull down the server 1 so that it is showing the server you added. From that point, the WLAN will send request to the ACS for login information.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
