5508 web authentication timeout problem
recep.sefer
Level 4
Level 4
If any authenticated user uses protocol other than (http, https) within timeout period,
that user is deuthenticated, why? solution?
sudkulka
Are you referring to idle timeout OR session timeout?
Once a web auth client is authenticated, he has full access and can run any protocol unless
- restricted by an ACL on controller OR switch with gateway OR firewall.
c) On WLC CLI, run
config paging disable
show run-config
show traplog
show msglog
b) From switch that has L3 SVI for the guest subnet, send
show run interface vlan x
