5508 Wireless Controller Initial Install
1alan.scott
Community Member
Hello Everyone,
First time poster.  I am setting up a PoC lab and just started to configure the Cisco 5508 wireless controller.  After the initial installation and the system reloading I found I was able to ping from my controller to the services port default gateway but I have not been able to ping from the management interface to the management default gateway.
My interfaces are up as shown below but ping is not working.  Being as I am new to Cisco Wireless can anyone provide some guidence on this matter?  Is this a firewall setting?
Interface Name                   Port Vlan Id  IP Address      Type    Ap Mgr Guest
management                       8    138      10.12.138.1     Static  Yes    No
service-port                     N/A  N/A      10.12.28.162    Static  No     No
virtual                          N/A  N/A      1.1.1.1         Static  No     No
(Cisco Controller) >show port sum
           STP   Admin   Physical   Physical   Link   Link
Pr  Type   Stat   Mode     Mode      Status   Status  Trap     POE    SFPType
1  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A     Not Present
2  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A     Not Present
3  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A     Not Present
4  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A     Not Present
5  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A     Not Present
6  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A     Not Present
7  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A     Not Present
8  Normal  Forw Enable  Auto       1000 Full  Up     Enable  N/A     1000BaseTX
I have an SFP module on port 8 to a Cisco 3560 switch Gi0/2.  On both devices I have up and up interfaces with a straight through cable.  I also tried a cross over with the same results.
2 Accepted Solutions
Your switchports are set for access ports and the WLC is set to tag. Can you change either the WLC to untagged (vlan id 0) or switch the Gi0/2 int to a trunk?
Well you are tagging 138 on the WLC and on the switch, so that should work.
Like blakerone mentioned, try to set the switchport to trunk but set the native vlan to vlan 138 and change the vlan id on the wlc to 0 "untagged".  Or else you can keep the vlan tagging on the wlc to 138 and just set the switchport to trunk and not have the native vlan assigned.
-Scott
7 Replies 7
Scott Fella
You should never have network connectivity between the management interface and the service port. It will break. The service port is for out of band management and if you want to connect that to the network, then make sure you do not route between the two.
Scott Fella
Sent from my iPhone
-Scott
adam.sibille
Community Member
Alan,
You'll want to connect to the WLC using the management address for configuration.
Stephen Rodriguez
Piggy backing on Scott, your WLC service port should not exist in any subnet the WLC is aware of.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
1alan.scott
Community Member
All,
Thanks for thereplies so far.  I have removed the cable from the services port to my 3560 switch.  On the switch I hae two VLANs set up and I had the services port on VLAN 28 and the management port on VLAN 138.
Now that the services port is unplugged I still can not ping between the management port 8 on my WLC and the default gateway 3560 switch VLAN 138.
Understand that all I did so far is the initial config straight out the box.  All interfaces are up so layer 1 and 2 seem good but I do see errors on the switch interface????  hmmm.  Here are the relevant settings I did and again only the manament interface port 8 is connected to the cisco switch and I have nothing else on the cisco switch.  No DHCP, NTP anything.
Interface Name................................... management
MAC Address...................................... 70:81:05:1f:c5:60
IP Address....................................... 10.12.138.1
IP Netmask....................................... 255.255.254.0
IP Gateway....................................... 10.12.138.5
External NAT IP State............................ Disabled
External NAT IP Address.......................... 0.0.0.0
VLAN............................................. 138
Quarantine-vlan.................................. 0
Active Physical Port............................. 8
Primary Physical Port............................ 8
Backup Physical Port............................. Unconfigured
Primary DHCP Server.............................. 10.12.29.50
Secondary DHCP Server............................ Unconfigured
DHCP Option 82................................... Disabled
ACL.............................................. Unconfigured
AP Manager....................................... Yes
Guest Interface.................................. No
L2 Multicast..................................... Disabled
(Cisco Controller) >ping 10.12.138.5
Send count=3, Receive count=0 from 10.12.138.5
and my switch config BTW I see errors on the interface Gi0/2 incrementing
FLRHO01-LAB3560-SW1#sh interfaces gig 0/2
GigabitEthernet0/2 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 001b.d530.7c02 (bia 001b.d530.7c02)
  Description: FLRHO01-5508-AIR1 Wireless Controller
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 154/255, txload 1/255, rxload 1/255
  Keepalive not set
  Full-duplex, 1000Mb/s, link type is auto, media type is 10/100/1000BaseTX SFP
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:39, output 00:00:00, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     1148 packets input, 3217008 bytes, 0 no buffer
     Received 1148 broadcasts (0 multicast)
     44741 runts, 0 giants, 0 throttles
     44742 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 1148 multicast, 0 pause input
     35523 packets output, 2670822 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     reliability 160/255, txload 1/255, rxload 1/255
  Keepalive not set
  Last input 00:00:36, output 00:00:01, output hang never
     1149 packets input, 3219748 bytes, 0 no buffer
     Received 1149 broadcasts (0 multicast)
    44779 runts, 0 giants, 0 throttles
     44779 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 1149 multicast, 0 pause input
     35552 packets output, 2673022 bytes, 0 underruns
FLRHO01-LAB3560-SW1#sh ip int brief
Interface              IP-Address      OK? Method Status                Protocol
Vlan1                  unassigned      YES NVRAM  administratively down down
Vlan138                10.12.138.5     YES manual up                    up
GigabitEthernet0/2     unassigned      YES unset  up                    up
interface GigabitEthernet0/2
description FLRHO01-5508-AIR1 Wireless Controller
switchport access vlan 138
switchport mode access
spanning-tree portfast
interface Vlan138
description Wireless Network
ip address 10.12.138.5 255.255.254.0 interface GigabitEthernet0/2
-Scott
1alan.scott
Community Member
Thank you guys good job its working now.
switchport trunk allowed vlan 138
switchport mode trunk
FLRHO01-LAB3560-SW1#ping 10.12.138.1
Sending 5, 100-byte ICMP Echos to 10.12.138.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
