5508 WLC Interface Groups
awatson20
Level 7
Level 7
We have not configured or used interface groups in our wireless deployments, and I am just curious if there are any issues or caveats experienced with using these?  We have a few instances where we have setup a /23 network for a specific wlan.  I  undertsand this increases broadcasts.  Would interface groups be preferred over using a /23 or even maybe a /22 to accomodate addressing?
Scott Fella
By default, the WLC will not forward broadcast.  There are pro's an con's to interface groups... if your doing multicast, that can be an issue unless you specify an multicast vlan.  I have used interface groups because customer standardize on /24, so I would combine a bunch of /24's to create an interface group.  I have customers with /23 and /23 and others with no issues... but I look at it as on the wired side.  You okay with /23 and or /22 on the wired side?
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
Scott Fella
Scott
-Scott
We have only use /23 in a few instances.  No issues currently.  Thanks.
You are good.... /23 isn't bad at all.  I have to deal with customers who have /16's and wireless and wired on the same subnet:(
Scott
-Scott
