5508 WLC Upgrade steps
Troy F
Single 5508 WLC with 8 x 1142 APs.
5508 is running FUS 1.3, software version 7.0.116.0, field recovery image 6.0.182.0.
I need to bring the software version up to at least 7.2.115 to support 2 new 2602 AP i need to install.
Question is; do I install FUS 1.9 then update my controller to 7.6.120 or do I need to do any intermediate steps?
This is my first time upgrading a WLC so I'm fresh and this is a production WLC.
Cheers
just adding more links
http://jackstromberg.com/2014/04/tutorial-upgrading-the-firmware-on-a-cisco-5508-wireless-lan-controller/
http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn7-0.html
http://www.cisco.com/c/en/us/tech/wireless-2f-mobility/wireless-lan-wlan/tech-configuration-examples-list.html
Sandeep Choudhary
Hi Fisher.
Normally It doesn't matter as long as you get it done but make sure that you reboot the WLC before doing the next.
Here is the procedure for FUS upgrade:
http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/fus_rn_OL-31390-01.html
WLC Software upgrade Procedure:
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/68835-wlc-upgrade.html
Dont forget to rate helpful posts
Thank you both for the replies, I'd already got the documents for the WLC and FUS upgrade, but the tutorial really simplified it. Thanks.
